New Stroker New Noise
soomuchpie
Post by soomuchpie »
Howdy!
I wanted a sanity check on this clatter, tick, whatver flavor of noise descriptor you prefer... I don't think it was present in the first couple hundred miles but I have about 500+ miles on it now and it's really standing out to me. Any educated guesses or strong opinions welcome Video below.
https://www.youtube.com/watch?v=osOjNz ... e=youtu.be
The facts...
1. It doesn't make noise until the engine is at temp. So no noise on startup and can let it idle and rev it up cold will not get the noise. Noise is present until engine cooled off completely and start cold again.
2. Noise does follow RPMS but it seems a little offset from them, hard to explain, like they are a little delayed. Doesn't really come across in the vid.
3. Broke in the cam with Lucas break in oil and now I'm running 10w30 rotella T6 feel free to roast me
4. Just changed the oil at ~500 miles and nothing notable in the oil or filter metal wise
5. Put the stethoscope everywhere and really the only place I can really hear it is on the lip of the bell housing.
6. Flex plate bolts are TIGHT
7. Noise is present with load, no load doesn't seem to matter. Once i get above 2k rpms the noise is drowned out but I think it's still there.
8. I smoke tested the exhaust system (when cold) and didn't see any leaks.
Re: New Stroker New Noise
I don't hear anything untoward in the video. If you've upgraded the camshaft and added stiffer valve springs, a little valve train noise would be normal.
soomuchpie
Thanks for checking it out. That's good to hear but I worry the noise isn't coming through as intensely in the video. Sometimes when I'm driving it sounds like I have an exhaust leak like when passing parked cars or retaining walls and the sound bounces back. It doesn't sound like a smooth sound. Anyone else? I put the stethoscope on it again today and could hear it pretty clearly on the bottom rear of the pan under the oil drain plug. Oddly enough after doing a spin and a couple WOT pulls for tuning logs I came home and the noise was less pronounced than when I left... frustrating
A guess of mine is maybe one of the rods is interfering with the girdle which I did use spacers for but did not measure clearance. That would be a relief...ish. I'm tempted to pull the pan to get some peace of mind.
mpgMike
Vehicle Year: 1995
Vehicle Model: ZJ
Post by mpgMike »
You would be able to see marks on the connecting rods if one (or more) were hitting the girdle.
soomuchpie wrote: February 6th, 2026, 5:15 pmA guess of mine is maybe one of the rods is interfering with the girdle which I did use spacers for but did not measure clearance. That would be a relief...ish. I'm tempted to pull the pan to get some peace of mind.
If I were you I'd do it and hope that the oil doesn't contain any forbidden glitter.
soomuchpie
So how much metal is too much metal? This oil is fairly new but have to assume this stuff has come from the past 500 miles (when i put a different cam, lifters, and head. about 1000 total on the crank and pistons.
Dropped the pan I see this metal in the pan and oil has some silvery sheen to it but isn't magnetic.Oil is fairly fresh only a couple hundred miles. On first glance the rod bearings don't have any obvious play. I don't think the girdle is the issue either. I see some scoring in the cylinders (which i also saw when I had the head off) but didn't seem too concerning. Going to let this drip overnight and check out some bearings tomorrow.
mpgMike
Vehicle Year: 1995
Vehicle Model: ZJ
Post by mpgMike »
Oof!
look up inside the block at the cam bearings...are they being squished out?
you posted you put a new cam in...what's the lift?
soomuchpie
So i looked pretty close and no evidence of cam bearings getting squished. Had a few mins so pulled first rod bearing, just the one that was down and closest so #2. Not looking great
https://imgur.com/a/f5hGAJ5
Were the bearing clearances checked before the engine was reassembled? The uneven wear pattern suggests there might have been residual dirt inside the block's oil galleries.
soomuchpie
Thanks for looking. Unfortunately only spot checked so not all bearings were measured but the ones i did were all in spec. Kicking myself fot that now. I have the engine out and tore down at the moment and rod bearings 2 and 5 were the worst of it. Some light scoring and pitting on the main bearings. See image below. Plan right now is to get the crank polished and while I'm at it deck the block some more to accommodate for the aluminum head per Russ's rec. Still not sure about the noise... everything seemed tight and flex plate was all good.
Going to double check the crank for straightness too tho it spins really well. the 2 and 5 bearing match makes me a little nervous but will see what the machine shop has to say.
https://imgur.com/a/69eMMCq
