4.8 stroker build
cal
Stroker Displacement: 4.71
Re: 4.8 stroker build
Post by cal »
Wait what
Why
cal
Post by cal »
NM. Misread.
SkylinesSuck
Post by SkylinesSuck »
I'm still confused like you were before re-reading. Help?
cal
Post by cal »
He was deshrouding the area around the valves. He just worded it weird and scribing the 4" bore was confusing, but makes sense to me now.
SkylinesSuck
I'm tracking now. Thanks.
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
Sorry. That was the best way I could come up to describe it at the time. I didn't take a picture.
I bolted the head to the bare block. I then reached up into the cylinders from the bottom with a scribe and marked the cylinder head where the 4" bore meets the cylinder head. The flat surface of the head was hanging in the cylinder all the way around the bore. I left the 2 quench areas and unshrouded the valves out to the scribed line. I hope that makes better sense.
1994 Sahara YJ
SkylinesSuck
At first glance, I think we both read it as you were going to remove material from the head everywhere inside the scribed line including the squish pads.
cal
Post by cal »
^^ exactly. it was the scribed line that confused us. totally makes sense though looking at it now.
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
Started roughing in the head ports.
1994 Sahara YJ
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
1994 Sahara YJ
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
Closer view of combustion chamber.
1994 Sahara YJ
Xtultegra
Learning to use the board
Vehicle Year: 1991
Post by Xtultegra »
Very cool. Thanks for sharing!!
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
:wiggle: No, my project is not dead, but I have come back around to it. Making progress again on the cylinder head. Initial flow numbers look good. I need to blend the bowls after cutting for bigger valves and see if I can increase exhaust flow. I did notice the swirl was low and surging from .200 to .400 lift. I hope to rectify that before finishing.
1994 Sahara YJ
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
1994 Sahara YJ
GreenYJ
Vehicle Year: 1994
Post by GreenYJ »
1994 Sahara YJ
Users browsing this forum: Bing [Bot] and 0 guests
