Alright, I have just started the install of my stroker engine on my project YJ. Here is what I have so far:
4.7 Stroker
AX-15
8.8 Rear Axle
Waggy 44 Front Axle
I am reusing the AX-15 from the YJ. I just had an interesting thing brought up though. The original 4.2 engine used a carb. So that means there was no computer. I did get the wiring harness that came with the engine.
I am installing the transmission this weekend. Now I am beginning to think about how the harness hooks to the transmission. I think the computer is going to be looking to the transmission for some info.
What do you guys recommend? Is there a way to reuse the tranny, or will I need to get one with the right sensors in it?
AX-15 with a Stroker
hvacman
Re: AX-15 with a Stroker
The only info from the ax15 tranny/x-fer case is the speed sensor.
hvacman
Someone just told me about a crank sensor. I was also told to use a different flywheel.
My problem is that the old AX-15 was to a carb engine. I am now going to a throttle body HO engine.
Any ideas on this?
Any ideas on this?
- Plechtan
- Vehicle Model: Comanche
Read This:
http://www.jeepstrokers.com/forum/viewt ... f=5&t=1447
You do need some kind of Crank position sensor.
Peter Lechtanski
- Biggrnjeep97
After extensive research, i wound up purchasing a kit from Advance Adapters to control the crank trigger. There are 2 companies on the market making balancer crank triggers, Advance Adapters and Hesco. Advance was cheaper from Summit racing by ~$30. Novak Conversions also has some good tech on there website and tech line. As in the post noted above, I contacted both Advance Adapters and Hesco about making my own crank trigger. I was told by both that it was proprietary info that they would not sell to the public.
Hope this helps. Post up what you end up doin.
-Will
http://www.advanceadapters.com/
http://www.novak-adapt.com/knowledge/tr ... ateway.htm
http://www.hescosc.com/shop.asp?catID=7533
-Will
- IH 392
If your bellhousing doesn't have the window for the pickup, you simply should have gotten a later bellhousing and use the stock pickup unit, probably way cheaper than any of those relocation kits?
- Biggrnjeep97
Touche'!IH 392 wrote:If your bellhousing doesn't have the window for the pickup, you simply should have gotten a later bellhousing and use the stock pickup unit, probably way cheaper than any of those relocation kits?
- Plechtan
Don't forget, you would also need the correct flywheel with the notches in it.
Peter Lechtanski
- IH 392
True, and the correct one for you application too(Renix, OBDI these two MAY? be the same?, OBDII), I got one from the junk yard for $35, it was the WRONG onePlechtan wrote:IH 392 wrote:If your bellhousing doesn't have the window for the pickup, you simply should have gotten a later bellhousing and use the stock pickup unit, probably way cheaper than any of those relocation kits?
Users browsing this forum: No registered users and 40 guests
