Compression Calculator Update - Version 2.0 Now Live!
Check here for most things forum related... NOT stroker related!
The Compression Ratio Calculator has been completely redesigned and upgraded with several user-friendly improvements:
What's New:
  • Smoother Performance - Calculations happen automatically as you type
  • Camshafts - Added a few more and validated specs of existing ones.
  • Mobile Friendly - Actually usable on a mobile device!
  • Improved Print View - Cleaner layout and better formatting when printing your results
  • Keyboard Navigation - You can now tab through all preset and camshaft selections using your keyboard
  • Form Reset - Added a reset to defaults button
  • Better Error Messages - Clear, helpful feedback if you enter invalid values (no more silent failures)
What You'll Notice:
  • Completely new look!
  • Collapsible Sections
  • The calculator validates your inputs and tells you exactly what's wrong if there's an issue
  • Results update automatically after you stop typing! No need to hit the calculate button
  • Print output now shows all your selections and specs in a clean, professional format
Nothing Changed:
  • All the same calculations and accuracy you're used to
  • Same presets
  • Your favorite camshaft specs are all still there
Everything works exactly as before—just better!
Let me know if you have any questions or notice any issues. All suggestions and feedback are welcome!
