4 to 6
matty401
4 to 6
Post by matty401 »
i have a nephew that is swapping a 4 cyl to a 4.0 auto in a wrangler i think it is a 89 what does he have to do to complete this doner jeep is complete and running thanks
Re: 4 to 6
I've never screwed with the 2 bangers?, but IIRC they don't share the same bellhousing?, you'll need to swap the trans with the engine.
matty401
Re: 4 to 6
Post by matty401 »
he is using the 4.0 trans and transfer case in the swap
Shade_Tree
Vehicle Year: 1994
Re: 4 to 6
Post by Shade_Tree »
I'm currently doing the same or at least gathering all the information first. From what I understand, he'll have to move the engine mounts back about two inches. The transmission mounts can accommodate so they don't require movement. The engine, transmission and transfer case all end up being ~2" further back...this makes the front drive shaft ~2" too short, you can pick up a 4.0 front driveshaft from a junkyard readily through www.car-part.com
For the rear driveshaft I was intent on using a slip yoke eliminator which of course means I was already going to have to buy a rear driveshaft.
