4 to 6
- IH 392
Re: 4 to 6
I've never screwed with the 2 bangers?, but IIRC they don't share the same bellhousing?, you'll need to swap the trans with the engine.
matty401
Re: 4 to 6
he is using the 4.0 trans and transfer case in the swap
Shade_Tree
- Vehicle Year: 1994
Re: 4 to 6
I'm currently doing the same or at least gathering all the information first. From what I understand, he'll have to move the engine mounts back about two inches. The transmission mounts can accommodate so they don't require movement. The engine, transmission and transfer case all end up being ~2" further back...this makes the front drive shaft ~2" too short, you can pick up a 4.0 front driveshaft from a junkyard readily through www.car-part.com
For the rear driveshaft I was intent on using a slip yoke eliminator which of course means I was already going to have to buy a rear driveshaft.
Users browsing this forum: No registered users and 15 guests
