It's ALIVE !!! Again!! with VIDEO
Bike Guy
Vehicle Year: 1991
Vehicle Make: JEEP
Post by Bike Guy »
I think I finally figured out all the fuel issues (the right injectors, H.P. Fuel pump, adj. regulator, fuel filter, the list went on and on :doh: ).
Check out the video, let me know what you think.
I think it's finally time to Dyno!! :cheers:
Turn up the Volume!
http://www.youtube.com/watch?v=ujMUtExiYxU
91 YJ, 4.0 Magnum, 4.10 Hp D30 ARB & 4.10 8.8 ARB, 5.0 AtlasII, BrownDog block & M.M., 6" BDS SUA lift, 35x12.5x15 Maxxis C/C, T-R B/L's, M.C. seats & belts, P.S.C. Armor, PSC steering & BLA-BLA mods! We WILL NOT FORGET 9/11!
1992Rotbox
Re: It's ALIVE !!! Again!! with VIDEO
Post by 1992Rotbox »
Sounds mean, love the polished VC
What size tires are you running for the dyno test?
Bike Guy
Vehicle Year: 1991
Vehicle Make: JEEP
Post by Bike Guy »
1992Rotbox wrote:Sounds mean, love the polished VC - Thanks, I cut the fins off with a Port-a-band and started sanding. Four hours later it was time to start polishing!!
What size tires are you running for the dyno test? - My street tires = 33x12.5x15 BFG A/T's (beats the heck out of trying to get descent #'s with my 110# each 35" Maxxis C/C on Trail-Ready HD B/L's wheels :doh:
Bike Guy
Vehicle Year: 1991
Vehicle Make: JEEP
Post by Bike Guy »
I've had a handful of people ask about the spec's on the motor, so I thought I'd post them here with the Video!
Motor: Magnum I-6
Head Mods = Port matched & polish, Enlarge Valve bowls & polish, Mill down Head, Flow Benched - results (25% increase in flow) Work By SCH RACING HEADS , Mopar Performance Ultra Thin multi-layer Head Gasket (to boost compression) - results (140-150 PSI)
Valve Train Mods = Mopar Performance Stage II Cam, Mopar Performance HD rocker-arm assembly, Trend custom push-rods, Crowler cam-saver lifters, Coyles Double Roller Chain & Gears, R&D Off-Road Custom valve cover
Oiling Mods = Hesco Blue-Printed High Volume oil pump w/dist. lube-tube & H.V. pick up, Trans-Dapt oil filter Remote relocation System, AMSOIL high zinc synthetic oil with a over sized NanoFiber Filter
Cooling System Mods = FlowKooler High-Flow water pump, Hesco H.F. water inlet housing, Milodon H.F. 195 deg. Thermostat, Performance Radiator - 3 core CBR all metal Radiator, Flex-a-lite HD Fan Clutch, Flex-a-lite 6-blade Clutch Fan, Jegs
sealed recirculating overflow Tank
Air Mods = Banks Ram-Air intake system (97-06), BBK 62mm Performance-Power-Plus series Throttle body, Custom 62mm throttle Spacer, '2000' Intake Manifold w/Polished runners
Fuel Mods = R&D Off-Road custom injector harness, Bosch 4-hole 20# (Black Jack) H.P. injectors, Hesco adjustable High Pressure fuel regulator 46 psi - results brings the injectors up to 22# (stock system is 19# at 39psi), Walbro 255LPH High Performance fuel Pump, GenRight Crawler Extreme 17 gal. aluminum fuel Tank
Ignition Mods = Sreamin' Demon Coil, 10mm Livewires spark-plug wires, Fire Power Distributor & Rotor cap, E3 spark Plugs
Exhaust Mods = Borla T-304 Stainless Header (1998-99), with S/S 2 1/2" head pipe, MagnaFlow H.F. Cat., Custom Cat.-back 2 1/2" exhaust w/Performance Brand H.F. muffler
Engine Restraints = Brown Dog 1" Poly Motor mounts and Brown Dog Super engine brackets (15 bolts total to hold the Beast in)
:cheers:
Users browsing this forum: No registered users and 48 guests
