Where does this go pt. 1
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
OK I'm at the point of having the handfull of parts at the end ( or close to it )
I would like to pick your collective brains here!
Most of the unknown parts are gaskets, or in this case an "O" ring.
Three O rings in the gasket kit; lg., med., and small. Where does the small one go?
Large
Med.
and small.
Part that bolts into block that holds oil filter (dim)
More to come! There are about 6 gaskets that I can't identify.
Thanks!
J.B.
Re: Where does this go pt. 1
Look at the second picture... Next to the finger nail that is pointing to the outer medium size o-ring that has the smaller one on it. See where the bolt is there?? Look at the pic again closer and you can see the o-ring on the bolt right next to your nail.
Hope that helps.
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
Here?
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
Yep, that was it. It was flattened and hard as my grannies tonails.
Tnx.
More to come! I think I will open them all under the same thread, just one at a time. Thanks again!
J.B.
Users browsing this forum: No registered users and 15 guests
