Last headgasket question ?
amceaglesx4
- Vehicle Year: 1981
- Vehicle Make: amc
- Vehicle Model: eaglesx4
Finally my 4.7 is in and now just need the headgasket. Hopefully the Gods here
will answer. So.... what I picked up is a Fel pro 36761 which according to the parts guy is a 43-51 thou head gasket with a 3.998 bore opening. Will this work for me ? Its not the Mopar p4529242 or the Victor Renix 54249. Am I okay with this ? They also had a felpro 26211 and another part number ( 9076 PT-1 ) which was a 40 thou. I literally have everything togather and the head, intake, carb, and exhaust manifold hanging on the cherry over the engine. I just need the gasket now. Super excited !!! Thanks
Re: Last headgasket question ?
Is it a MLS gasket?
amceaglesx4
- Vehicle Make: amc
Not sure what that means friend. there is metal in the gasket material that I can see. The head is a 95 7120 and a 99 block.
amceaglesx4
- Vehicle Make: amc
Shit !!! This gasket doesn't have the triangle water jackets. The block and head do though.
Does it look like this:
If so its a MLS (Multi Layer Steel) Gasket. It compresses to .043"
It won't. The triangle ports don't match the head gasket. Only small circles in the head gasket. No gasket has a true match to the triangle holes.amceaglesx4 wrote:Shit !!! This gasket doesn't have the triangle water jackets. The block and head do though.
amceaglesx4
- Vehicle Make: amc
Basically yes besides mine has a thin orange/red silicone small bead. Mine has the mall circle holes. Yea coolant will pass through that lol. m guessing I can use the one I have then ? Is yours 60 over too ?
amceaglesx4
- Vehicle Make: amc
No metal rivets on mine though.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
