Header collector question for stroker
nicpaige
- Vehicle Make: XJ
- Vehicle Model: Sport
I have searched and have seen some people say so and so has a 2.5" collector but when I look up the actual part they advertise 2.125" as the largest. FlowTech advertises 2.500", does anyone have personal experience with these? I have used their stuff before and wasnt real impressed. Can someone name a brand other than FlowTech that has an actual 2.500" collector size? I will be using the Edelbrock head which advertises the pre 1999 exhaust port locations. Thanks
nicpaige
- Vehicle Make: XJ
Re: Header collector question for stroker
The thorley I am running has a 2.5" collector. but their adapter and donut gasket necks down to 2.125". I'm going to replace it with a standard 2.5" flange. However, I can't recommend Thorley's support.
mountaineerjeff
- Stroker Displacement: 4.0
I'm also gonna go with the "guess not" answer. I looked and couldn't find anything so I eventually had to get one of the available headers and I just modified it to run a full 3" setup.
My Borla 17039 is 2.25" w/ s-pipe and the NOS Clifford single outlet header I recently picked up is 2.5"(I want to chop an inch off and weld on a 3" flange). I've read that the Pacesetter is 2.5", but is iffy on alignment/quality. You can also get Clifford's newer dual outlet header and they sell a y that merges it into a single 2.5" (maybe get a custom merge to 3"). Isn't the Banks revolver a 2.5" outlet?
embs2001
- Vehicle Model: comanche
Where did you see pacesetter being 2.5? I read 2 inch collector which seems small. http://www.jegs.com/webapp/wcs/stores/s ... sce+setter
1988 Comanche w/ m90
Build thread- http://www.naxja.org/forum/showthread.php?t=1118735
nicpaige
- Vehicle Make: XJ
I assumed the PaceSetter header was two 2" collectors then into one ? pipe. That dual slip on pipe feature looks like an exhaust leak nightmare to me.
mountaineerjeff
Pacesetter is what I started with.
embs2001
Is the final collector bigger than the middle two? 2.5 inch?
nicpaige
- Vehicle Make: XJ
The end collector on that does look bigger than the other two. Was it possible mountaineerjeff to install that header with the pipes welded like that? That would solve the leak issue.mountaineerjeff wrote:Pacesetter is what I started with.
6TIME
- Vehicle Year: 1993
- Vehicle Make: JEEP
- Vehicle Model: CHEROKEE
I'm running a Gibson Revolver stainless header and it measured 2.5" at the outlet pn 51327. Looks like some sources have it listed at 2" but that's incorrect.
mountaineerjeff
Installed...after I welded a 3" flange for true full 3".
- beater_renix
- Vehicle Year: 1989
Captain Obvious here: You can save time and money when setting up your new header by making sure your down pipe and front drive-shaft don't occupy the same space.
-Awesome Quote...
Beater_Renix
Beater_Renix
the_wrench116
old news but I did this years ago. and it still works great. it would be easy enough to make another one as I still have the spare engine and transmission.
