Finally a 3" Down/Y Pipe for the I 6
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
Post by akadeutsch »
I really want a true 3" exhaust all the way from the header back. So, Im going to order a new down pipe from Ebay. It will cost under 100 USD shipped to my door. Then I am going to take it to an exhaust shop and see how much they want to build me a True 3" version. Is anyone else interested in one of these? Im thinking that it may be cheaper if I order a few of them. I'll post again when I find out what they will cost.
mark2215
Learning to use the board
Vehicle Year: 2005
Re: Finally a 3" Down/Y Pipe for the I 6
Post by mark2215 »
I had mine done this past fall. My 2005 requires the twin mini-cats on the downpipe so there was no way I was fitting 3" mini-cats in there. What we did is modify the JBA header, which has a 2.5" collector but then they add the silly ball flange which restricts it to around 1.5. We cut off the ball flange so it was a true 2.5", then went double 2.5" pre-cats to 3" from the y back. I'm really happy with the exhaust although it wasn't cheap but 304ss isn't ever cheap. Here are a few pics.
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
Wow. Good work. I don't have the pre cats on my truck. I was thinking that I would leave the header alone and use very similar dual pipes to the ones already in use. I just want them to collect to a 3" pipe before the cat. I don't think that the dual 2" down pipes are the restriction in the system. So I want to leave the two pipes at 2". BTW That is a beautiful piece, Well done!
Damn that is some beautiful work. I also don't think the 2" from the header is a restriction. It does look like there is a restriction from the Y to the 3" down pipe. You could have just simed the cats out (if you could pass emissions) and ran a standard cat in the main exhaust.
While I can't use the 3" down pipe right now I would be interested in a 3" mandrel pipe for future use.
nicpaige
Consistent
Consistent
Vehicle Make: XJ
Vehicle Model: Sport
Post by nicpaige »
Well done sir. :cheers:
That pre-cat pipe looks great Mark. One of my projects this spring is to cut a NOS Clifford header with single 2.5" output flange up an inch or so and weld on a 3" flange, then have a custom 3" s-pipe fabbed by MBS to the 2.5" Banks cat-back. I haven't done my research if it's kosher to weld onto a ceramic-coated header or if I should even care what happens to the coating.
You will have to grind away the coating around the weld. The coating near the weld will be compromised as well.
tysonxj
Post by tysonxj »
I am interested.
the_wrench116
Post by the_wrench116 »
very nice looking work!!!
