my first stroker.need help
shadowg1200
Vehicle Model: xj
Post by shadowg1200 »
hi
i m planning to do my second stroker and i need help
actuly my first stroker was mini stroker and i m happy about the result....but i want to do my next stroker 4.8l in my another xj.
i have ordered the parts already but i m not sure about the calculation
4.8L stroker
~ Jeep 4.2L 5.875" rods
~ 4.0 bore pistons -sum-17350-00 6cc
~ CompCams #68-232-4 camshaft
~ Mill block deck 0.025"
~ Ported HO 1.91"/1.50" cylinder head
~ Stock 0.051" head gasket
~ almost 0.100" quench height
i think the comp ratio will be 10.5:1
do u think there is any thing wrong???????????
sorry for my languege :oops: :oops:
sly-jeeper
Vehicle Year: 1994
Vehicle Model: cherokee
Re: my first stroker.need help
Post by sly-jeeper »
any reason you want to run those pistons?
shadowg1200
Vehicle Model: xj
because its price and availabilty here
also the block i have is already ported to this size.
also because the compression distance is 1.560
It's risky boring the cylinders out to 4.00" without first having them sonic checked for thickness. Even if they turn out to be OK, I suggest you use the longer 4.0L rods and go for a set of custom pistons. Those Chevy pistons are too short and will leave the quench height too high. The engine might run but it's likely to detonate even on premium fuel with a combination of high CR and high quench.
If the cylinders won't take a +0.125" overbore, I suggest you play it safe and go +0.030" for a 4.6L stroker using 4.0L rods & Keith Black IC944 pistons.
