pilot bearings?
vashxj
Vehicle Year: 1999
Vehicle Model: cherokee
pilot bearings?
Post by vashxj »
Hey I cant seem to find a straight answer on this, I cant find it in faqs or searching. So do all 4.0/4.2 cranks have the same pilot bearing hole? I know all the input shafts on the trans side may be different but im swapping my auto to a ax-15 and I have the 4cw long noose crank. If I had to guess I would say they are, just wondering if anyone has run into this
Re: pilot bearings?
Apparently not?, the clutch kit I got for my Wrangler came with two pilot bearings?, I'm not going to stuff one in the crank until I get the thing apart to see what I really need?
vashxj
Vehicle Year: 1999
Re: pilot bearings?
Post by vashxj »
are both the outer diameters of those bearings the same?
Re: pilot bearings?
vashxj wrote:Hey I cant seem to find a straight answer on this
Here's a straight answer for you:
'92-'99 AX15 and NVG3550: OEM pilot bearing 53009180AB for '87-'91 engine or stroker
I'm using the pilot bearing 53009180AB.
vashxj
Vehicle Year: 1999
Re: pilot bearings?
Post by vashxj »
thanks I just wasnt sure it the back of the crank was the same, haven't taken it apart yet and probably wont until its atleast 40-50 degrees out
Re: pilot bearings?
vashxj wrote:are both the outer diameters of those bearings the same?
NO!
the grey ghost
Stroker Displacement: 4.611
Vehicle Model: comanche
Re: pilot bearings?
Post by the grey ghost »
Prob the smaller one
RADARGUS
Stroker Displacement: 4.0
Vehicle Year: 1999
Re: pilot bearings?
Post by RADARGUS »
So, we are having this issue with our stroker. The pilot bearing for the 99 transmission does not fit the 4.2 crank we installed. The pilot bearing for the 4.2 crank has a smaller inside diameter for the older transmission.
Does the 53009180AB pilot bearing fix this issue?
Any suggestion is greatly appreciated.
Re: pilot bearings?
RADARGUS wrote: May 1st, 2025, 10:39 amDoes the 53009180AB pilot bearing fix this issue?
Yes.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Majestic-12 [Bot] and 7 guests
