my1990 renix eliminator stroker
- DaemonForce
- Stroker Displacement: 4.7L Super
- Vehicle Year: 1983
- Vehicle Make: American
- Vehicle Model: Eagle
Re: my1990 renix eliminator stroker
God that head looked like yuck. It's come a long way. Good job.
,__,_____,__, ~A-M-C YA!
//___}/,_ll,_\__\,_____
,l_/¯\_l__ll__l__/¯\(¤≡¤)
(o))o)) (o))o))
(o))o)) (o))o))
- Stroker Displacement: 4.611
- Vehicle Model: comanche
Yeah I found out the head was worked once before, so when I ported it and then had another valve job done it set the valves back in the head quite a bit, so I worked on it a little more afterwards and eventually got the right pushrods. I actually just bought another head to replace this one
- DaemonForce
I bought an incomplete Renix engine with 188K on it that turned out to be total junk. I salvaged the block but will swap in a high output head. I'm still messing with valves but noticed a trend. Any time these engines have more than 50K on them, the intake valves clean up without fuss but every exhaust valve is poor, pitted and unbelievably nasty. I'll probably order a new set of valves in the morning and these things aren't cheap unless going through JC Whitney. I don't want to borrow any valves from the old head but I think it might be a good idea at this point.
(o))o)) (o))o))
(o))o)) (o))o))
I can't find my pictures of the head before it went together
Just installed ev6 22.5 lb/he at 43.5 psi injectors, still had to trim them back, my guess is our new engines are so much more efficient that the bsfc is lower than anticipated
The original renix 4.0 i own comes out to .475 bsfc per the witch hunter calculator, if my horsepower/torque rating are in the 260 to 270 range that puts me somewhere around .40 : ) give or take .02
Front number cover I made fit with light holes for my foglights that are recessed inside the heavy steel bumper
Whats on the hood?
My intake breather
And a rag
- I love this board
good choice in color
Just installed new fuel pressure reg. From 95 chry. Minivan 3.3 , 41-48psi , 150% better
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
