my1990 renix eliminator stroker
- DaemonForce
- Stroker Displacement: 4.7L Super
- Vehicle Year: 1983
- Vehicle Make: American
- Vehicle Model: Eagle
Re: my1990 renix eliminator stroker
God that head looked like yuck. It's come a long way. Good job.
,__,_____,__, ~A-M-C YA!
//___}/,_ll,_\__\,_____
,l_/¯\_l__ll__l__/¯\(¤≡¤)
(o))o)) (o))o))
(o))o)) (o))o))
the grey ghost
- Stroker Displacement: 4.611
- Vehicle Model: comanche
Yeah I found out the head was worked once before, so when I ported it and then had another valve job done it set the valves back in the head quite a bit, so I worked on it a little more afterwards and eventually got the right pushrods. I actually just bought another head to replace this one
- DaemonForce
I bought an incomplete Renix engine with 188K on it that turned out to be total junk. I salvaged the block but will swap in a high output head. I'm still messing with valves but noticed a trend. Any time these engines have more than 50K on them, the intake valves clean up without fuss but every exhaust valve is poor, pitted and unbelievably nasty. I'll probably order a new set of valves in the morning and these things aren't cheap unless going through JC Whitney. I don't want to borrow any valves from the old head but I think it might be a good idea at this point.
(o))o)) (o))o))
(o))o)) (o))o))
the grey ghost
I can't find my pictures of the head before it went together
the grey ghost
Just installed ev6 22.5 lb/he at 43.5 psi injectors, still had to trim them back, my guess is our new engines are so much more efficient that the bsfc is lower than anticipated
the grey ghost
The original renix 4.0 i own comes out to .475 bsfc per the witch hunter calculator, if my horsepower/torque rating are in the 260 to 270 range that puts me somewhere around .40 : ) give or take .02
the grey ghost
Front number cover I made fit with light holes for my foglights that are recessed inside the heavy steel bumper
Whats on the hood?
the grey ghost
My intake breather
the grey ghost
And a rag
the grey ghost
the grey ghost
shawnxj
- I love this board
good choice in color
the grey ghost
Just installed new fuel pressure reg. From 95 chry. Minivan 3.3 , 41-48psi , 150% better
Users browsing this forum: Amazon [Bot] and 4 guests
