Stock pistons have a compression height of 1.601". Unfortunately all the aftermarket pistons are shorter and the Speed Pro H802CP's are the tallest of them with a compression height of 1.592". Those pistons have a 15.2cc dish so if you left the block undecked, the quench height would be 0.073" and the SCR would be 9.9:1 (assuming 57cc head). You could gain some volume and lower the SCR by polishing the combustion chambers and piston dishes to a near mirror-like finish.Jr. Mechanic wrote:If I went with these:
http://www.summitracing.com/parts/slp-h ... /overview/
What would the 1.592 compression distance do compared to the stock pistons?
If I were to leave my deck height alone and go with the .073 quench, what would the negative effects be other than definitely requiring premium fuel? Is there a thinner head gasket available than .043?
Alternatively you could use the 4.0L rods with IC944 pistons (21cc dish). With the block undecked the quench height would be 0.070" and the SCR would be lower at 9.4:1. This rod/piston combo would allow you to set the SCR at your desired level but with a lower quench height.
