TPS % on Scanner
superstingray77
Vehicle Year: 1999
Vehicle Model: WJ
TPS % on Scanner
Post by superstingray77 »
I have searched but not located a good explanation of this:
Why does my TPS% on the scanner show 16.7% at idle and only 77.8% at WOT?
Using a MOPAR sensor, TV(trans cable) is not restricting my throttle any, and linkage has full throttle range.
Re: TPS % on Scanner
When you consider that a TPS of 100% is the reference voltage of ~5v, your idle TPS is ~0.83v and WOT is ~3.89v and those are right on the money.
CobraMarty
Post by CobraMarty »
Mine reads 14.7% at idle.
99 XJ M62 S/C
superstingray77
Vehicle Year: 1999
Vehicle Model: WJ
Perfect, 505 performance tried to tell me that the idle should read 0%. Just didnt sound correct to me as I was following the same logic as you guys.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
