push rod and cam question
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: push rod and cam question
any chance you could grab a casting number and a picture of the crack on that head?
- vashxj
it was a 0630 head ill post pics tonight now i got a 7120 head i like the temp sensor hole i can use that for my elec. fans sensor
92tank
- Stroker Displacement: 4.5
i have seen a 0630 head crack in the same place
- vashxj
between cyl 1 and 2 its hard to see
and cyl 3 into the surface
Cracks in the head around the valve seats are usually a sign that the head's been overheated.
- IH 392
Yep, the cover on my '00 core is the EXACT same cover that's on my '97.SilverXJ wrote:I would prefer the nipple. My stock 2000 Cover had one.
I agree, that engine has been COOKED!!!Cheromaniac wrote:Cracks in the head around the valve seats are usually a sign that the head's been overheated.
- vashxj
ya bad things happened in there, that was off a 98 my new one looks good its off a 93 the #2 piston was blown up but the head looks good so far
- vashxj
another question whats the best oil/way to break in the new cam
Valvoline VR1 with some GM EOS additive for the cam break-in.vashxj wrote:another question whats the best oil/way to break in the new cam
There are a fer break in oil available. I would recommend Joe Gibbs or Brad Penn. Just use their oil straight, no additives.vashxj wrote:another question whats the best oil/way to break in the new cam
- vashxj
thanks alot you guys i got to put it on as soon as i get the head back this week, cuz im going to byron dragway the 15. and my springs are still on back order. im going to use the new stock ones i have for the break in. i might have to race on those if the performace ones dont get here in time
Retlaw01XJ
Be careful, you'll be running the stock springs in the danger zone!vashxj wrote:im going to use the new stock ones i have for the break in. i might have to race on those if the performace ones dont get here in time
My stock 2001 springs would coil bind (stack solid) at 1.120". At a 1.64" installed height, there's 0.520" left for valve lift.....subtract the 0.060" safety margin, and those springs are only good for 0.460" lift. The Comp cam you mentioned has 0.485" lift.... more lift than is safe for those springs.
Walt K
Eastern Pa
Eastern Pa
- vashxj
good point thanks for saying something i didnt really pay attention
Retlaw01XJ
Just trying to keep you out of trouble!vashxj wrote:good point thanks for saying something i didnt really pay attention
Walt K
Eastern Pa
Eastern Pa
- vashxj
hey so how beneficial is exhaust wrap anyway, i was thinking of doing that before i put the header on but it is ceramic coated to. guess it wont hurt to put on wrap
Users browsing this forum: Bing [Bot] and 15 guests
