New forged pistons are HERE!
Jeepsr4ever
Where's the "any" key?
Stroker Displacement: 491ci
Vehicle Year: 1974
Vehicle Model: cj5
Post by Jeepsr4ever »
Thanks to all involved with exception to the forging house which help us at bay for almost a YEAR! :mad3: But we are past that now :D Preorders have shipped today already and you will get your pistons by weeks end. Thank you for your patience folks we sincerely appreciate it!
We can do any compression same price
You can buy them here
http://www.bulltear.com/catalog/
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Re: New forged pistons are HERE!
Post by jbxx »
I am very exited! I have everything I need and I was one of the first pre-orders.
The build begins!
J.B.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
that is a sexy piston!
brewmenn
Post by brewmenn »
Can these be made to work with the Eagle 6.150 long forged con rods?
What is the pin height? Can it be changed?
Jeepsr4ever
Vehicle Year: 1974
Vehicle Model: cj5
I designed the parameters for the forge tool and yes we can make a piston to suit that rod
I6FAN
Stroker Displacement: 4.2
Vehicle Year: 1987
Post by I6FAN »
Nice looking pistons! Do you have an approximate pin and piston weight. What would the minimum compression height without getting into the oil ring?
Jeepsr4ever
Vehicle Year: 1974
Vehicle Model: cj5
I do not have a weight on them they wont be the lightest piston out there but definately not a heavy piston, but I cannot say at this time. I would not be afraid to put the pin into the oil rings...ring lands take care of all that. We can go around 1.15 maybe smaller depending on the rings you would want to use.
I6FAN
Vehicle Year: 1987
Post by I6FAN »
Awesome!
This may open allot of opportunities for rod choices. Stock rod 6.123" + (1.38-1.15) = 6.353" connecting rod potential. Assuming a stock deck height block and 1.38" comp height to yield a zero deck clarence set-up, then decreasing the comp height to 1.15", and adding that diff. in comp height to obtain longer rod length (somebody please check me on this). There are allot of forged 6.2", h and I beam rods out there, although, not sure about big end widths on those though.
Jeepsr4ever
Vehicle Year: 1974
Vehicle Model: cj5
These particular pistons were:
3.905 diameter
1.380 CH
5/64 5/64 3/16
28CC dish
But they can be made to suit just about any build for no extra.
4.whoa
Vehicle Model: xj&mj
Post by 4.whoa »
Do you offer any coatings?
-Russ
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
I get about 15.75 oz for the piston.
J.B.
Jeepsr4ever
Vehicle Year: 1974
Vehicle Model: cj5
Thats just under 450 grams. Not a heavy heavy piston and not the lightest piston in racing. As far as coatings go there are some really good sources if you want to run ceramic hard coat on the top and if you would like a teflon skirt but we do not offer the coatings that would be a customer responsibility but if you order a set you want coated please let us know it can change the finish dimensions of the piston and may change the machined size.
Jeepsr4ever
Vehicle Year: 1974
Vehicle Model: cj5
jbxx wrote:I get about 15.75 oz for the piston.
J.B.
J.B. weigh a stock piston when you get a chance.
I6FAN
Vehicle Year: 1987
Post by I6FAN »
J.B.
FSM is showing 510-514 grams (less pin). It shows the same weight for the 4.2l piston which is .125" less diameter??? So, x2 on getting that actual weight.
450g is a good weight for a piston this size. It would be light for 4"+ piston, but for 3.875"+ size that seems about right. Don't mean to seem "hung-up" about weight, but one of the best things for reducing the harmonic in the I6 engine is to reduce the recipricating weight at each crank throw; pistons like these combined with a forged steel rod (~565g) would give a 16-17% weight reduction from the stock components, which in turn, will reduce some of the crank flexing during the harmonic!
Users browsing this forum: Mrtyu718 and 2 guests
