Valve problems: Mopar Performance valve springs, retainers
qualm
- Vehicle Make: JEEP
So my engine is at the builders and he said that there is a problem with the valves and the the Mopar performance springs, locks and retainers. I have part numbers P4452032, P4529218, and P5249464. The problem is that my valves are 3 groove and the Mopar keepers are 1 groove. Also if we try to use the stock keepers the retainers and the valve sit flush. So do I have the wrong parts? Or do I get the earlier valves from the 1998 and earlier engines? No one seems to mention this when they recomment the Mopar Performance stuff for later engines.
Thanks,
Qualm
Thanks,
Qualm
Re: Valve problems: Mopar Performance valve springs, retainers
The Mopar retainers are meant to be uses on the earlier single groove valves. You might want to look at retainers from a Hemi possibly as they have 3 grooves.
Your stock locks should work.
qualm
dwg86 wrote:Your stock locks should work.
Already tried this and it does not work. The retainers and the end of the valve, that the spring and retainer go on sit flush. There is nowhere for the pushrod to sit.
SilverXJ wrote:The Mopar retainers are meant to be uses on the earlier single groove valves. You might want to look at retainers from a Hemi possibly as they have 3 grooves.
So it is now a guessing game? Has anyone else had this issue? Could I should buy the single groove valves and call it good?
I meant to say locks, not retainers.
qualm
SilverXJ wrote:I meant to say locks, not retainers.
So where would I start with the locks from Mopar? Any suggestions?
If I bought the old style valves would that work?
Yes, you can buy valves with one lock groove, or you can use the stock 3 groove locks. It would be cheaper to use your stock locks.
qualm
The stock locks will not work.dwg86 wrote:Yes, you can buy valves with one lock groove, or you can use the stock 3 groove locks. It would be cheaper to use your stock locks.
The old style valves will work fine. However, I would ask your machinist if he has a lock solution that would work with your valves and the mopar retainers. Perhaps one of the new hemi locks might work.
qualm
I believe all the hemi stuff is 7mm.
dragginwagon406
How did you end up solving the lock issue?
That would be the best solution. I had used the same Mopar springs/retainers/locks when I first built my stroker, but my valves had single groove stems and everything went together perfectly.qualm wrote:Could I should buy the single groove valves and call it good?
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
