Adjustable MAP issues
bill_durango
Vehicle Model: yj
Post by bill_durango »
4.7 stroker, 24 lbs injectors and trying to install an adjustable MAP, but I keep throwing Codes on my OBD1, indicating Voltage is too high? I have tried setting the adjuster everywhere between 4.6 VDC and 5.6 VDC and I keep getting engine codes right after start up. Do Adjustable MAP's have to run through a relay and wait to be switched on after the jeep is started?
Re: Adjustable MAP issues
No, it doesn't have to be run through a relay but the 12v supply should only be active when you turn the ignition switch on. Here's my schematic:
95jeepxj
Vehicle Year: 1995
Vehicle Model: cherokee
Post by 95jeepxj »
does anyone make one that is ready to hook up. i really dont want to make my own.
sorry for asking a ? on ur post
Jeff Leigh sells them for $25:
http://www.strokedjeep.com/regulator.html
