lol i posted that but started a new page.
i meant about the driving thing. i remember you were so excited driving it when you actually got to for the short time, if im thinking of the same guy.
I will be watching your progress on this ... sounds very interesting!! I am a programmer but haven't messed around with boards yet. I might get one just to mess around with it.SilverXJ wrote:I am also working on a DIY digital gauge setup using an Autometer pressure sending unit, ISSPro temp senders, an Arduino board, and a 16x2 (or 20x2) LCD screen. I thought about going with standard 2 1/16" VDO gauges, but the only mounting solution would have been on the A-pillar and at that price I would only have two gauges. This way I intend to monitor transmission temp, oil temp, oil pressure and vacuum all in one display. The Arduino can also be programed for many other gauges and features such as a below spec warning, data logging, etc. Seems like a fun device. I'm just hopping I remember my C programming well enough.
Good idea on the lube. I used plenty of ARP assembly lube (for torquing their bolts) on the cam and lifters. Maybe that saved me since I had forgotten an oil galley plug, remember???SilverXJ wrote:I will use moly lube on the can journals and lobes. I will be using the original lifters as I kept them in order so I don't have to do a cam break in again, which means a nice easy first start.
Users browsing this forum: No registered users and 11 guests
