Renix head cracks
- 4.whoa
- Vehicle Model: xj&mj
Renix head cracks
Has anyone had issues with renix heads cracking? I have 2 @ the machine shop being checked out and BOTH are cracked between the valves on cyl #1
I'm going to pick them up tomorrow, I have 1 more renix head and a 7120 to drop off for checking. I'm building a mostly stocker in an '87xj, so I wasn't wanting to use my spare 7120 on this build. I was wondering if anyone else was having problems with these.
-Russ
rammit11
Re: Renix head cracks
i have a 0630 head from a 97 grand cherokee motor that I am building as a stroker that i believe is cracked in the same area. I don't have it in my hands yet still at the shop with the block, ended up getting a second head which was good. Just my thoughts here , doesn't seem to make a difference as to what year or motor the head is just how hard they were run or overheated.
- IH 392
Depending on how bad the crack is, the head may be able to be cut for seat inserts, fixed tons of Chivy heads that way.
- 4.whoa
I'll be able to find out better tomorrow. I was hoping for a quick cleanup to get it together quick and cheap
-Russ
- 4.whoa
Well, talked to shop again . . My 3rd renix head is also cracked
But my 7120 isn't
. So. I guess ill be updating it. I have one bad one stripped and the crack looks about 1/4" deep- into port. I tried to get some pics but I can't get close enough to see it without being blurry.
I asked them about new seats and he said he didn't think it would hold a seal without being welded. I don't think that head is worth it. . . .so I'm messing with making the renix tps work on the H.O. tb. I saw a link somewhere here about using part of the ho tps on the renix one so I'm gonna try it
any tips
-Russ
- Plechtan
- Vehicle Model: Comanche
Why stick with a Renix head? An HO flows better.
Peter Lechtanski
- 4.whoa
Yes, but I WAS just gonna stay stock save for. A mild cam. Its going in a '87xj for my dad, he needs something that'll get him around in the snow this winter. I was gonna put the HO head/int/tb on MY '87 mj , but oh well, guess he gets the guinea pig
-Russ
