Factory Serpentine 4.2L Crank? Cut it?
TheSpecialist
Vehicle Year: 1982
Vehicle Model: Scrambler
Post by TheSpecialist »
I have a 1982 CJ-8 with California emissions. The belt setup seems to be factory serpentine. Any info on this? I am about to pull it and combine with a 1993 Wrangler 4.0L HO and want to know if I need to have the end of the crank machined. All the crank facts I have read say they are all the same length, but a quick measurement with a tape shows the dampener/pulley are the same distance (OC) from the block as the 4.0L setup.
5-90
Re: Factory Serpentine 4.2L Crank? Cut it?
Post by 5-90 »
Typically, it's the earlier cranks you have to have machined - where you have 10m/m taken off of the nose on the V-belt setups. Snake-belt setups for the 258ci crank should drop right into the 242ci block without any trouble.
StroktWJ
Vehicle Model: Grand Cher
Post by StroktWJ »
I believe the crank number for the 4.2 crank that you dont have to remove any of the snout was the #727
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
laxplayermjd
Post by laxplayermjd »
when talking to my machine shop about this issue. it seemed the cheaper way out was to buy the hesco spacer for 35 than go through the extra work for machining.
BMW Master Tech
ASE Master Tech
Even BMW guys need a toy.
In process 4.6l Renix Build.
ccpanel
Stroker Displacement: 275
Vehicle Year: 1950
Vehicle Make: chevy
Vehicle Model: truck
Post by ccpanel »
TheSpecialist wrote:I have a 1982 CJ-8 with California emissions. The belt setup seems to be factory serpentine. Any info on this? I am about to pull it and combine with a 1993 Wrangler 4.0L HO and want to know if I need to have the end of the crank machined. All the crank facts I have read say they are all the same length, but a quick measurement with a tape shows the dampener/pulley are the same distance (OC) from the block as the 4.0L setup.
BTT
i tried to measure my setup in compared to a 4.0 but i forgot to do it before i stripped the 4.0-same question...
brokenujoint
Vehicle Model: Tj
Post by brokenujoint »
i've talked to 3 different machine shops. 2 of them looked at me like i was crazy. the other one said sure no problem. we just have to send it to a guy we know. he wanted like 250.00 just to cut off the excess then re balance it. i'm not always the sharpest tool in the shed but 250 minus 35 = 215 bucks in savings by just throwing on the Hesco spacer. 35.00 seems ridiculous for a stupid spacer but its necessary. ordered mine 3 days ago.
Exos
Consistent
Consistent
Post by Exos »
My crank shop cut mine, no extra charge... 10mm was taken off, and you could not tell it has been done.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
brokenujoint wrote:he wanted like 250.00 just to cut off the excess then re balance it.
holy crapanolie! how much is balancing alone worth?
brokenujoint
Vehicle Model: Tj
yeah i know... i bought the whole ground crank balanced for 150.00.. this dude was one of those perfectionist drag strip a holes... i almost started laughing when he quoted me that price.
Bodo
Post by Bodo »
brokenujoint wrote:yeah i know... i bought the whole ground crank balanced for 150.00..
I've seen those cranks and you get what you pay for...
