THE VERY FIRST TIME
the_wrench116
THE VERY FIRST TIME
Post by the_wrench116 »
hey i have a 91 block a 12cw crank and a set of 4.0L rods a 68-232-4 comp cams bump stick and a 91 head assembled main and rod bearings.
still need lifters, timing set, injectors,head gasket, ARP studs, pistons ( dish size? looking to run 9.5:1+-.25 static)
what do i need to get this thing together did i miss any thing????? :doh:
i know i will need to have my block bored at least .030 may be .060 as the #1 top piston ring broke and wore a BIG grove in the bore.
Plechtan
Re: THE VERY FIRST TIME
Post by Plechtan »
91 head? That's not an HO is it? I would see if you could get a later head and intake. look at the recipies and FAQ to see where to go. If you look through all of tha and still have questions people on the forum will be happy to answer them.
Peter Lechtanski
91-95 is HO. Casting # 7120.
the_wrench116
yes its a HO head and block sorry didnt think to mention it :doh:
ajmorell
Vehicle Model: ZJ
Post by ajmorell »
With the 4.0 rods you are looking at expensive forged pistons, KB's or Hesco's most likely.
-Andy-
MichiganTech Mechanical Engineering
BSME '09
MSME '10
the_wrench116
are they the only ones readily available? and are they reliable? how many of you have them an have put 75k+ miles on them.
ajmorell
Vehicle Model: ZJ
Post by ajmorell »
the_wrench116 wrote:are they the only ones readily available? and are they reliable? how many of you have them an have put 75k+ miles on them.
AFAIK the only pistons available for use with the 4.0 rods are forged. Aside from being a bit noisy at startup forged pistons are significantly better than cast IMO.
-Andy-
BSME '09
MSME '10
the_wrench116
AFAIK??? whats this mean?
need forged pistons to run boost :hrhr:
Flash
Post by Flash »
the_wrench116 wrote:AFAIK??? whats this mean?
As Far As I Know =AFAIK ;)
the_wrench116
got an octopus manifold(99+) complete. from flebay 150 shipped did i do good?
I can get them bare for $25.47+tax at my local JY, probably 90-100 w/ tb and fuel rail. $75-100 seems to be the norm on the forums and on ebay.
Users browsing this forum: Amazon [Bot] and 14 guests
