Cam bearings and freeze plugs
jn2630
Learning to use the board
Vehicle Year: 1993
Post by jn2630 »
Are cam bearings and freeze plugs from a 4.2 interchangeable with a 4.0?
eastin82
Re: Cam bearings and freeze plugs
Post by eastin82 »
i think cam bearings are not sure on freeze plugs
keepin the five alive!
Plechtan
Post by Plechtan »
freeze plugs are not
Peter Lechtanski
Some of the 4.2 freeze plugs will fit, but if you order a kit for the 4.2 you will be short other freeze plugs. I thought I purchased a kit for the 4.0L engine, but it was for the 4.2 engine. We used what could fit and then had to order two more plugs.
Maddawg
Vehicle Model: G.Cherokee
Post by Maddawg »
My freeze plug package says short block plugs 242 (4.0) 6cyl engine and I have tried everything oil, assembly lube even loctite like it said at circle track http://www.circletrack.com/enginetech/c ... index.html , but sure can't get them in. I have seal driver and the hole seems clean. I tried different holes as well. :brickwall:
2000 Grand Cherokee 4.6
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Maddawg
Post by Maddawg »
One more thing. They are steel, plug says it's 2" .Rough measurement is about 2.03" .Hole approx .195"
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Maddawg
Post by Maddawg »
Sorry head up butt. Hole approx 1.95" :smack:
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Users browsing this forum: No registered users and 17 guests
