I've got a 1992 Wrangler YJ with a running 4.0 in it and I want to build a stroker on the side, then swap it in once it's done and keep driving the YJ as my daily/weekend rig in the meantime. Heads up that I'm pretty new to this. I've got barely basic mechanical knowledge and skill, so I'm trying to learn as I go.
A few things I'm trying to figure out before I buy a donor engine:
1) which donor years and models should I be looking for, and are certain 4.0 blocks better suited to a stroker build than others. Should I be shopping by model year or do I need to get into specific casting numbers to know what I'm actually getting?
2) I want to retain my YJ's existing PCM, wiring, distributor, and accessories where I can, so I'm trying to understand what donor engines will bolt up and play nice with that setup versus which ones would force me into a bunch of extra changes.
3) I remember reading about a cracking issue on the TJ 4.0 and I believe it was the cylinder head. I don't remember the details though. Which years and castings had the problem, and how do I tell a corrected head from a bad one when I'm looking at a used engine?
4)Assuming one of the later engines has the corrected head, would that make a better donor overall, or would an earlier engine actually make the swap simpler even with the head issue factored in?
End goal is a reliable, street driven stroker with good low end torque and a nice HP improvement. Nothing crazy, reliability is key. What donor would you look for in my position, and what would you steer clear of?
Looking forward to being a part of this amazing community. Thanks for your time.
Two Engines, One ‘92 YJ: A Slow Stroker Swap
SquareFace
Littlehunter
- Vehicle Year: 1989
- Vehicle Model: xj
Re: Two Engines, One ‘92 YJ: A Slow Stroker Swap
I built up a 92 YJ a little under 20 years ago. Honestly, I don't think I'd bother stroking a 92 YJ. Just me though so I'm not trying to crap on your idea.
I ran mine on 33's with 4 inch suspension, 3 inch body lift. I swapped out the 3:73 diffs for 4:10's and had the motor rebuilt stock. It was really an incredible change to the jeep. Felt like a 4x4 sports car on the road LOL Mine was a 5speed stick shift. I guess bigger tires and diffs would probably use the power a stroker will give you.
I'm absolutely no expert on stokers. I'm having the dilemna myself with basically all the same questions you have except I'm dealing with an 89 renix 4.0 in a XJ. To stroke or not to stroke.. the difference between that and a straight rebuild for me is about 1800. (canadian) if all goes smooth. So 5K or 7K paying a reputable shop ..... it's a dilemna.
