My 258 overheated due to a cooling problem. Now it sounds like a diesel at idle with the hood up, but you can't really hear it with the hood closed.
What is the likely problem?
What is cause behind a 258 sounding a little like a diesel?
CJ-8_Jim
Stroker: 4.59L, SCR 9.47, Hesco 1995 MPI with adjustable FPR, TJ intake connected to grill, aftermarket OEM-size exhaust.
CJ-8: mostly stock, but becoming less so.
D44 rear, 2.73 gears on 31", T-176
- IH 392
Re: What is cause behind a 258 sounding a little like a diesel?
They are subject to excessive rocker arm bridge wear and lifter noise, that's probably what you're hearing?
- SkylinesSuck
Something warped from the heat possibly causing a broken piston/skirt? Anything like that making noise is going to require the motor coming apart.
