Help simulate the 4.0 in Engine Analyzer Pro
1bolt
Post by 1bolt »
Okay I may be biting off more than I can chew here so I wonder if any one else wants to help.
Engine Analyzer Pro (EAPro) can be found at http://www.performancetrends.com/ they have a trial version.
To give a great example of what i can use help with: "Bearing size" is a coefficient that EAPro calculates (you'll have to get the program to really see what I mean) it's a coefficient based off the number and size of all short block bearings. For EAPro to calculate the number it needs the numbers of cam, rod, main, bearings (that's easy enough) and the diameter and width of each one as well (Micrometer time)! I can go measure these and I will if no one wants to help.
I could also use the total specs of the factory Cam (or cams if you're up to it, there are a few variations that would be interesting). And the same complete specs for some of the most popular aftermarket Cams.
Again check out EAPro to see we're not just talking about centerline, lift and duration here. There are 15 fields for a Cams Intake and the same 15 for exhaust!
Here's another one, in Cam/Valve Train specs, there's a radio button for "Calculate Valve train dynamics", and "see specs for dynamics" which allows you to input the specs including the weight of things like Springs and pushrods etc. You could spend half a day with a postal scale alone just gathering this data.
What am I going to do? I am looking at flow testing all the air and exhaust components to get accurate CFM numbers for things like both old and new Intake runners, ports (on Renix, 7120 and 0331 heads, as well as mild and heavilly ported heads), Exhaust which will allow EAPro to caluculate a discharge coefficient for every part of the intake and exhaust system. The TB (stock and bored and ported/bored).
I don't even have adaptors made to hook up some of this stuff to the flow bench yet, so my plate is full (and like I said I might be biting off more than I can chew already). It actually calculates a discharge coefficient based on not just CFM, but port area (which gets velocity), which means a much more realistic torque curve can be generated... Very impressive.
We could put approximate numbers in there or flow numbers from other people's claimed head flows, but the problem is they wont be all from the same source, and in some cases no one has ever even flowed them. That road definitely wont lead to accuracy once you start throwing mods into the mix.
Who knows the total CFM passed by the Stock factory exhaust system from the down pipe to the tail pipe? What you don't know? Yeah me either.
:doh:
Simon
Boilermaker
Re: Help simulate the 4.0 in Engine Analyzer Pro
Post by Boilermaker »
Here is what i'm using for the factory cam (most of the numbers came straight out of the 1991 fsm):
I've tried to model a few other cams, the isky 133125/26 and the Lunati Voodoo 63501. Here's everything i've tried so far (zipped up to simplify download).
If there is anything i can do to help, please let me know.
Edit: here is where i got the numbers for aftermarket cams:
Lunati: http://www.lunaticams.com/Product.aspx?id=1476&gid=287
Isky: http://www.iskycams.com/timingchart.php ... hart_id=12
1992 MJ Eliminator
Stroker in progress: Lunati Cam, Diamond Pistons, 4.0L Rods, 4wt Crankshaft 3727 Casting, Clifford Ceramic Coated Header,
99+ Intake, 62mm Throttle Body, 24# Ford Injectors
Comp Cam distributes (free) a version of desktop dyno, but you are locked into using their cams. However, you can get a lot more specs from what that software has as far as their cams. What dimensions on the bearings do you need?
1bolt
Post by 1bolt »
Never mind I got the bearing measurements while I was measuring some other stuff.
Simon
1bolt
Post by 1bolt »
Anyone remember the exact plenum volume of the HO log style intake manifold, and the 99+ equal runner intake? Lee once posted the exact numbers but for some reason "plenum" doesn't find the reference on HESCO's board, and yes I searched the older archives as well. At one point I'm positive he stated the exact size of both plenums just can't find it.
Simon
yuppiexj
Post by yuppiexj »
Per http://www.go.jeep-xj.info/HowtoIntakeManifold1.htm
2600cc for the -99
4300cc for the 99.5+
1bolt
Post by 1bolt »
Well that's a start thanks YuppyXJ. The number I really need is the actual plenum without the runners. MadXJ just cc'd the whole intake. Actually I can probably just subtract the runner cross section and length if I can calulate how many cc's in each runner.
Lets see 1.5 x 1.25 and aproximately 8" long for the HO log and exactly 11.5 for the 99+ I get about 244cc per runner and 352cc per respectively. or 1464cc in the runners of the log and 2112cc.
Simon
Post by Flash »
1bolt, it probably a little to late but if you purchased this program you could choose from 7 different AMC 6 engs............Unfortunately the demo for this software will only let you play with basic setting unlike the one you have that let you play with all the bells........the only combo that is not availabe is the stroker...........i have to click on the 4.0L and then add the stroke of the 258.
Heres the link.
http://www.proracingsim.com/dynosimmainpage.htm
