Minimum head to piston clearance?
Just curious as what the minimum piston to head clearance is on our engine.. would it change if one went with a forger slug such as I am dong here: viewtopic.php?f=8&t=444
Mgardiner1
Stroker Displacement: 284 CI
Re: Minimum head to piston clearance?
Post by Mgardiner1 »
I think the listed in the FAQ section, there is mention of keeping it .040 or above. How much do forged pistons expand? I know the hypereutectic pistons expand the least, not sure how much of an impact that would have on engine running quench figures.
Found it
.However with piston expansion and rod stretch(AT HIGH RPM) the minimum clearance is .045"(absolute minimum is .040")
What exactly is considered high RPM though.
I sent an email to KB about what they recommend......
wasn't there a piston FAQ or am I having some sort of memory problems?
Mgardiner1
Piston FAQ found here: viewtopic.php?f=27&t=67
Quench FAQ found here: viewtopic.php?f=27&t=73
Post by Flash »
I real have been thinking of changing this..... However with piston expansion and rod stretch(AT HIGH RPM) the minimum clearance is .045"(absolute minimum is .040")
I truly believe that most of us(those staying with in the stock rev limit) could tighten the quench to .035" with out a problem..............But I'm only guessing so,.........I have left it as .040"
Got a reply from Keith Black
Hi Chris .060 or greater. Thanks Tech dept.
That seems huge to me.
seanyb505
Stroker Displacement: 280ci
Post by seanyb505 »
Maybe they didnt think it only revs to 5250?
97 XJ 4.6
90 MJ 4.0 - sold
Post by Flash »
SilverXJ wrote:Got a reply from Keith Black
There has been several that have set the quench between .040-.045 But if your going this low or close, your not building a simple stroker and you should be checking all aspects of it......like valve to piston as well as piston to head ;) .060" is just a c.y.a. number.
Ok.. so I follow up with Keith Black and ask how much the clearances would change once the piston is warmed up.
Hi Chris the wall clearance will grow some the height won't grow much as long as your rods are steel. You should be alright. Tech Dept.
So, then where did they get the .060" number from? I can understand accommodating for piston rock, but it shouldn't be that great to make the clearance so high.
