Oil Pan Fitment with HV Pump
Russ and myself were talking the other day about oil pan fitment and the Melling HV pump.
Been using the 91-95 YJ pans with no problems with HV pumps from Bennie.
http://www.hesco.us/products/7950/oil-p ... w16_On2Z6o
Pick up @ 3/16ths
The Renix pans are different for sure but are the XJ pre/post 96 XJ pans are a bit different then the YJ ?
Russ mentioned even the Moroso pan needed some love with the HV pump.
Comments, knowledge or part numbers ?
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Vehicle Model: eaglesx4
Re: Oil Pan Fitment with HV Pump
Post by amceaglesx4 »
Never owned a yj but just an idea which ive done in the past is cross reference based off ebay. Usually an item will tell for what applications it will fit. For example a 95 pan may be only compatible 91-95. You get the idea.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Heres one
2000-06 wrangler
99-04 gc
Oem number 5301034AB
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Xj
87-99 4.0
Part # 53020108
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Another pan is
87-92 xj
97-00 xj
93-98 gc
No oem number
If you bearing clearances are CORRECT, you don't need that oil heater. :brickwall:
That would be a debatable subject.
IH 392 wrote:If you bearing clearances are CORRECT, you don't need that oil heater. :brickwall:
You are absolutely INCORRECT.
ANY engine would benefit from pre-heating the engine oil before starting the engine.
jsawduste wrote:Russ and myself were talking the other day about oil pan fitment and the Melling HV pump.
My stroker is built with an '00 XJ block/oil pan and I also have a Melling HV oil pump. There was no problem with the pickup clearance but I needed to "massage" one area of the oil pan with a ballpeen hammer to clear the body of the oil pump.
http://www.angelfire.com/my/fan/HVOP.html
That`s just it Dino.
Using the YJ pan there hasn`t been any need to "customize" the pan side for the pump body.
Admit to not having looked up part numbers from the dealer (yet) to see if there is a difference between the families.
Was hoping someone might have a couple/few pans that could be laid side to side and compared. Say YJ, XJ early and then a TJ/XJ late for example.
Same here. 2000 XJ oil pan needed clearancing for the oil pump body.
jsawduste wrote:That`s just it Dino.
I'm also curious. There has to be a subtle difference between the XJ & YJ oil pans.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Well i left 2 part numbers for different pans.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Found a 09 thread on here called difference between two oil pans.
You didn't read the statement, the HV oil pump IS the oil heater, a stock pump provides all the oil an engine needs, WHY!?? heat the oil by PUKING it out of the bypass valve?? :huh:
