Double roller confusion
Posted: December 13th, 2015, 10:52 am
by amceaglesx4
Im a little lost here for a few reasons...
!- Since I have a 4.0 camshaft and a 258 crank do I need some crazy mix and match timing chain and gears ?
2- If not what do I need here ? There are a shit ton of choices.
Thanks :banghead:
Re: Double roller confusion
Posted: December 13th, 2015, 12:12 pm
No, Use a 4.0L timing set. I recommend the JP Performance/Rollermaster timing set.
Posted: December 13th, 2015, 1:12 pm
by jsawduste
SilverXJ wrote:No, Use a 4.0L timing set. I recommend the JP Performance/Rollermaster timing set.
available from Russ Pottenger on this forum.
Posted: December 13th, 2015, 6:43 pm
by amceaglesx4
Thanks friends.
Posted: January 10th, 2016, 1:01 pm
by amceaglesx4
The funds are starting to run low lol. Are all the timing chain camshaft gears all the same throughout the 242 and 258 ? I know the 99 I have is a newer camshaft bolt plate versus a 95. Obviously double roller gears are different. I might just go a single chain or a roller. I also read somewhere that a 93 or 94 was a stock oem roller chain. Anybody have any insight on this ?
Posted: January 10th, 2016, 2:16 pm
by Russ Pottenger
The early single roller factory 4.0 timing set was 87-93
The later set 94-98. 1999 and up was on the thrust plate cams.
If you're on a tight budget I would go with the early 87-93 set. They will be around $35.00
The billet gear double roller Rollmasters run $130.00
Russ
Posted: January 10th, 2016, 6:24 pm
by amceaglesx4
So the 87-93 was a factory roller and 94-01 was just a plain chain then ? Thanks Russ
