amceaglesx4
Posts: 324 Joined: December 5th, 2015, 5:26 pm
Vehicle Year: 1981
Vehicle Make: amc
Vehicle Model: eaglesx4
Post
by amceaglesx4 » December 13th, 2015, 10:52 am
Im a little lost here for a few reasons...
!- Since I have a 4.0 camshaft and a 258 crank do I need some crazy mix and match timing chain and gears ?
2- If not what do I need here ? There are a shit ton of choices.
Thanks
Posts: 5790 Joined: February 14th, 2008, 7:14 am
Post
by SilverXJ » December 13th, 2015, 12:12 pm
No, Use a 4.0L timing set. I recommend the JP Performance/Rollermaster timing set.
Posts: 1032 Joined: February 28th, 2008, 3:13 am
Post
by jsawduste » December 13th, 2015, 1:12 pm
SilverXJ wrote: No, Use a 4.0L timing set. I recommend the JP Performance/Rollermaster timing set.
available from Russ Pottenger on this forum.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Post
by amceaglesx4 » December 13th, 2015, 6:43 pm
Thanks friends.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Post
by amceaglesx4 » January 10th, 2016, 1:01 pm
The funds are starting to run low lol. Are all the timing chain camshaft gears all the same throughout the 242 and 258 ? I know the 99 I have is a newer camshaft bolt plate versus a 95. Obviously double roller gears are different. I might just go a single chain or a roller. I also read somewhere that a 93 or 94 was a stock oem roller chain. Anybody have any insight on this ?
Posts: 932 Joined: August 15th, 2009, 1:27 am
Post
by Russ Pottenger » January 10th, 2016, 2:16 pm
The early single roller factory 4.0 timing set was 87-93
The later set 94-98. 1999 and up was on the thrust plate cams.
If you're on a tight budget I would go with the early 87-93 set. They will be around $35.00
The billet gear double roller Rollmasters run $130.00
Russ
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Post
by amceaglesx4 » January 10th, 2016, 6:24 pm
So the 87-93 was a factory roller and 94-01 was just a plain chain then ? Thanks Russ
