Hi folks,
Can someone point me to a post that details compatibility between years and what, if anything, is different?
I am looking to put a stroked inline 6 from a 1994 XJ into my 1997 TJ.
Any issues, thoughts?
Brian in San Francisco
Compatible engine years: 1994 XJ into a 1997 TJ
norcalroots
- Stroker Displacement: 4.9
Re: Compatible engine years: 1994 XJ into a 1997 TJ
Block side engine mounts are different between the two
norcalroots
Is there a simple workaround for the location difference? Or is it a PITA?
Dallas can help with a conversion mount. We have done this several times already.
www.Stinkyfab.com
The OBD1 sensors (XJ) and the OBD2 (TJ) will need to be swapped.
www.Stinkyfab.com
norcalroots
If I have to change from OBDII to OBDI, I am guessing that would trip me up at the smog check here in California. I may need to head back to the drawing board.
Not knowing how the smog laws are in Ca, I can only say that the sensors have different connector ends and in some cases the pin out is different.
If its just the sensor issue it just a matter of swapping one for another to match your OBD1 harness. If they also look at the block year, well then your screwed.
