IMSA AMC Spirit
AMX's, Gremlins, Pacers, Ramblers, Eagles etc.
adtarr
Vehicle Year: 1979
Vehicle Make: AMC
Vehicle Model: Spirit
IMSA AMC Spirit
Post by adtarr »
I just joined the board and hope to leverage the knowledge on here. I am about to start building a 232 inline six for vintage road racing. Here are some of the basic rules.
Overbore no more then .047
Stock stroke must be retained.
Internals are free.
Iron heads only.
Headers/intake free.
Based on that I have a 232 I am going to put a 4.0 head. For the internals other then a stock crank I have the Eagle Steel Rods and will use forged pistons.
I have a Clifford header and intake and will run a Holley 2300 500cfm two barrel. The heads will get better valves and Harland Sharp roller rockers. Also have an aluminum flywheel but not sure about which balancer to use.
I am not overly worried about max power or trying to win races. I want a reliable motor that can 5-6 races per year and be semi competitive.
I was told these engines can run up to 6000-6200 RPM. Can anyone provide advice on building the engine? Tips, tricks, or things to look for? Any advice is most welcome.
Thanks
Adam
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Vehicle Model: eaglesx4
Re: IMSA AMC Spirit
Post by amceaglesx4 »
You won't win any with the 500cfm holley . Put on a 287 cfm motor craft 2100 or 2150 with the 1.08 venturi. Your current barrels are too big. You will have a HUGE improvement in acceleration with the smaller carb. Night anf day throttle response. I have several if your interested.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Re: IMSA AMC Spirit
Think I also have the 1.14 and 1.21 venturi models as well.
SIXPAK
Stroker Displacement: 280
Re: IMSA AMC Spirit
Post by SIXPAK »
adtarr wrote:I just joined the board and hope to leverage the knowledge on here. I am about to start building a 232 inline six for vintage road racing. Here are some of the basic rules.
Internals are free.
Iron heads only.
Thanks
Adam
If it were me I would try this. Use the 232 crank in a 4.0 block. The 4.0 is a 3.88 stock bore compared to the 232 being 3.750 bore. This will give you just a shade over 248 inches. Your Clifford intake will not line up with the ports on the 4.0 UNLESS it was bought for a 4.0 which they do sell. The header will need some mods also if it was for a 232/258. As far as carbs, I think the 500 cfm holley will be a good choice. But thats just my opinion for what its worth.
SIXPAK
Re: IMSA AMC Spirit
Post by SIXPAK »
On your pistons try a nice flat top with appropriate valve reliefs. Go with a good durable wrist pin as well. Cam wise, try something in a 240-ish at .050. No real need to go much over .500 lift unless you plan on some head work. A good valve job and some bowl work will serve you well. If you are going to spend money on any one item for me it would be a quality rocker arms. I have zero experience with the factory stamped rockers but I do know some poeple that have welled a brace across the top from side to side then have them cryoed. Of course that will only work if you go with a hyd cam but I would go with a solid instead.
I guess most of your motor plans will start with a budget, then concentrate on making a durable powerplant to maximize fun!
