Flexplate for AMC 904 trans to 4.0L?
PseudoSport
- Stroker Displacement: 4.0L Turbo
- Vehicle Year: 1995
I’m going to be swapping a 1997 4.0L into a 1982 AMC spirit which has a 904 transmission. Are there any 4.0L flexplates that will bolt up to the 904 converter? To make it easier I don’t have to worry about the crank trigger wheel pattern since I’m using megasquirt EFI.
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
SIXPAK
- Stroker Displacement: 280
Re: Flexplate for AMC 904 trans to 4.0L?
Yes there is a stock flexplate that you can use. There were some 904 transmissions behind 4.0's in a few years. I will try to come up with a number for you if the dealership cant help you. I use one myself right now in the race car.
PseudoSport
I'll have to dig though my stack of flexplates to see if I already have one that might work. What starter are you using with your flexplate? I read the 4.0 one is smaller then the 4.2.
SIXPAK
I am using a stock 4.0 starter and just fyi comp ratio is over 14 to one
