Perfect auto transmission for a 4.6
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
Post by akadeutsch »
My goal here is to have a discussion about automatic transmissions and which one can handle the most power.
My 2000wj came with a 42RE. I rebuilt it around 115,000 miles (I had it rebuilt by a professional). And now it is slipping again at 215,000 miles. Should I spend the time and money having the 42re rebuilt again ($1,400) or should I use another trany? what do you run behind your stroker? Please keep this conversation specific to auto trans. I am missing most of my right leg so driving a clutch is tough. :cheers:
Re: Perfect auto transmission for a 4.6
I'm not fond of any of the Chrysler transmissions, particularly the 42REtard. However, you have a difficult problem. Swapping in any other auto transmission is not an easy task, especially on the electrical end.
One option is talk to Martin Saine. He is well respected in the ZJ crowd. He might have an option for you http://www.thefastman.com/transmission.php.
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
It sounds like there would be a lot of work and research involved in any kind of swap, so I think I am stuck with the REtard.
Some good info in the 42REtard
"Jeep Grand Cherokee started using the 42RE transmission in 1993 1/2 models with the 4.0L engine. The "4" stands for 4-speed, "2" is for torque capacity, "R" is for rear-wheel drive, and "E" is for electronically controlled.
This transmission is electronically controlled using a governor pressure solenoid to vary the governor pressure. The shifts are controlled by the valve body by conventional shift valves for 1-2 and 2-3 upshifts. The 3-4 upshift and 4-3 downshifts are controlled by a solenoid. Although the shifts are controlled by shift valves for the lower gears, the higher gear is electronically controlled because the governor pressure acting against it is controlled by the transmission control module (TCM). The throttle pressure is controlled by a standard cable and throttle valve. The TCM inputs for this system include engine rpm, throttle position sensor, vehicle speed sensor, transmission output speed sensor, governor pressure sensor, transmission fluid temperature sensor and overdrive "off" switch. The TCM outputs are the 3-4 shift solenoid, the governor pressure solenoid and the torque converter clutch solenoid.
Here's how this system operates: As the output shaft begins to move, a 2-wire AC generator (transmission output speed sensor) begins to signal the TCM of the rpm. As the shaft speed increases, the TCM controls the governor pressure solenoid accordingly by a pulse-width modulated signal. Feedback to the TCM is provided by a governor pressure sensor to verify that the pressure actually changes. The pressure sensor is a 5-volt reference sensor. When the wheels are not rotating, voltage around 0.6 V is normal. As the wheels begin to speed up, the voltage should increase proportionately. If the voltage does increase, then the pressure is increasing as it should - this should be verified with a pressure gauge. This variance of pressure acts upon the shift valves in the valve body along with the throttle pressure to provide the shifts. As speed warrants, the TCM will apply the 3-4 overdrive solenoid, which is the only shift solenoid used on this system. The OD inputs are overdrive off switch, TPS, VSS, transmission temp sensor, output speed sensor and engine rpm. The torque converter clutch (TCC) solenoid will normally operate in overdrive, but the TCM can operate the TCC in third gear if the overdrive off switch is selected. Inputs for TCC include OD off switch, TPS, engine rpm, VSS, output speed and transmission temperature sensor.
The transmission temperature sensor is mounted on the overdrive/torque converter clutch solenoid assembly and provides input to the TCM. When the temperature sensor reports 30 degrees F or colder, there will be no overdrive, and below 50 degrees F, there will be no torque converter clutch. If the transmission fluid temperature sensor reports an overheating condition (over 260 degrees F) and the transmission is currently in overdrive, the TCM will downshift to third gear. The TCM will also light the LED in the dash-mounted OD off switch until the temperature drops below 230 degrees F. However, the torque converter clutch may still be operational.
This system has self-diagnostics. Fault codes can be read with a scan tool or by cycling the ignition key three times, then counting the flashes of the LED in the OD off switch. The diagnostic connector is located inside the vehicle to the left of the center console. The default mode of the TCM is third gear. Manual shifting of reverse and second gear is possible when in default mode. Default mode happens after a fault code is set."
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
"Level 10" makes what they call a "bullet proof" rebuild kit for the 42RE for 500 bucks. That is 200 over the cost of another kit. But I like the words bullet proof. Any one ever used it? :rockout:
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
Any one know the Torque Converter Stall Speed of a bone stock 2000 Jeep Grand Cherokee with a 42 RE?
FSM says 1800-2300 RPM.
SkauneJohan
Vehicle Year: 1995
Location: Skauneland (land of scania) the forgotten/ocupied country.....
Post by SkauneJohan »
now the stock aw4 used in cherokee XJ is pretty much bulletproof and almost same as the a340(i have heard) used in toyota supra
supposedly its just a matter of changing some friction discs and solenoids to make aw4 handle 400hp or so
dont take my word for any of this though
2,5" homebuilt catback and rugged ridge steel header (more to come)
dreaming of a stroker
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
And the 42re is just a 904 with electronics and an overdrive. The 904 has been used in drag racing for years and years behind 500 HP cars. I am happy with my four speed auto. Even if it does need a rebuild every 100,000 miles
wjtom
Vehicle Model: wj
Post by wjtom »
Exactly you can use the parts for a 904 in it.The overdrive is just a matter of converting it to a one ton unit so its just a matter of swapping parts and adding clutches.There is a 7 clutch overdrive brake kit available from red eagle.Same goes for adding clutches for the trans just swap the hubs from a 46re.Red eagle makes all the clutch packs to upgrade it so you can add even more clutches as theirs are thinner.Ive done two of these so far one in mine and one in my sons.There are a few other parts like converting to a gm pressure solenoid.But again just bolts in.Probably one of the easiest transmissions to rebuild no special tools required except a press fot the spring in the overdrive.Its 850lbs so dont try to take the snap ring out without it being in a press.Other than that not a big deal.
