Decking vs. thinner head gasket
In my build I plan on setting deck clearance at 0 and use a .051" gasket to set my quench. The reason for using the .051" head gasket is because 1) the .041" head gasket is only available from carquest, 2) possibly no availability in the future 3) can not be had in a multi layer steel gasket. #2 also means is if I have to replace the head gasket for any reason in the future and i can't get a .041" gasket I will have a quench of .061"
So anyhow... is there anything bad about decking or my logic?
- Mgardiner1
Re: Decking vs. thinner head gasket
Just make sure the machinist measures everything properly. I asked for a 0 deck clearance, and the machinist claimed he left .002 in the hole, but it really worked out to be .009 (avg) deck height which i wasn't too crazy about, but not pissed off enough to remove all the parts again and bring it back to the machinist.
- Alex22
I'm glad to see people planing ahead. We get customers who need work redone because one part or another is no longer available. Since you want a .051 quench height then I would just go with the thicker head gasket.SilverXJ wrote:In my build I plan on setting deck clearance at 0 and use a .051" gasket to set my quench. The reason for using the .051" head gasket is because 1) the .041" head gasket is only available from carquest, 2) possibly no availability in the future 3) can not be had in a multi layer steel gasket. #2 also means is if I have to replace the head gasket for any reason in the future and i can't get a .041" gasket I will have a quench of .061"
Is there only one company making a .041 thick head gasket?
~Alex
As far as I know the only company that makes them is Victor-Reinz
Yeah the victor-reinz/mopar performance P4529242 is the .043" HG. I ordered the gasket tear down kit P4529245 thinking it was gonna come with the .043", but it ended up being a Fel Pro .051" HG with the crappy cork valve cover gasket and 3-piece cork oil pan gasket(didn't use). If I ever have to take the head off, I will find a .043"(if carquest in fact has it). I asked the machinist to remove .030" from the deck and it came out to be .028", so I have .010-.011" deck clearance +.051"HG=.061-.062" quench.
I purchased one from them about two months ago..gradon wrote: I will find a .043"(if carquest in fact has it).
- 1bolt
Why not just zero deck either way? Whats the rod stretch going to be with stock con rods? .010 or .015? I'm asking here not stating... I seem to recall somewhere between .010" and .020"? There's nothing wrong with .041 quench... assuming your cam selection will allow the valves to clear... If not then machine some reliefs on the pistons
Also as others have noted already, the actual deck is going to end up proud of zero by a small bit anyway, because your machinist will likely only deck to the crown of the tallest (so to speak) piston and rod.
Simon
Simon
gremlinsteve
you will be fine with a steel rod with as much as a .035 quench. would not run any thing tighter. no real reason not to zero deck a motor anymore.
steve
steve
- John
That is the best approach, .040 -.060 quench is considered good. Either gasket will fall within that range on a 0 decked engine. Careful piston selection/dish size and cam selection and you are on your way to a well thought out build. And you still have adjustments to quench and compression by gasket selection.1bolt wrote:Why not just zero deck either way?
- IH 392
My Victor set# 95-3480VR has a the head gasket with # 5997 on the gasket, it measures .043 uncompressed, it says it's for '94-'95 year applications, it has the cork valve cover gasket, I haven't even looked to see if it's compatible with my late ('97) tin cover?
- seanyb505
- Stroker Displacement: 280ci
Just remember zero decking the block will require custom shorter pushrods. Or do what I did - deck the block and head enough to equal a total of .060 and use a .060 shim for the rocker arms.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
I don't think it is.IH 392 wrote: it has the cork valve cover gasket, I haven't even looked to see if it's compatible with my late ('97) tin cover?
Harland Sharp adjustable roller rockers.seanyb505 wrote:Just remember zero decking the block will require custom shorter pushrods. Or do what I did - deck the block and head enough to equal a total of .060 and use a .060 shim for the rocker arms.
- Mgardiner1
If you take .020 off the deck of the block, the machinist can probably take .020 of the top of the valve stems without affecting retainer clearance.
- Backwoods Rambler
Can anyone confirm this by measuring a loose valve stem they maybe have laying around?Mgardiner1 wrote:If you take .020 off the deck of the block, the machinist can probably take .020 of the top of the valve stems without affecting retainer clearance.
1998 XJ- Custom 4.5" suspension - 33" BFG MT's - Custom Bumpers - Custom Belly Skid - Custom Tire Carrier In Progress......Planning a stroker to help with the pop-up camper pulls,
Click HERE to Find out more about Project X-pedition
