tach signal, speedo problem
turbojeeper
Vehicle Year: 1989
Vehicle Model: comanche
Post by turbojeeper »
ok to start off with my jeep is running on ms. i hooked up the tach signal wire to the negative on the coil and i am getting a tach reading but it is way off. tuner studios shows idle at 750-800 and it feels like that, but the tach says 1300 rpm. my rev limiter is set at 5300 and when i feel it hit the tach show 7000+ rpm. i know the pcm supplied the tach signal and i am wondering if i just nee to buy an aftermarket tach or what?
problem 2. the speedometer. i have 8 volts running to the sensor and the sensor grounded where the cluster is grounded (on block) with it hooked up i still get no mph but the weird thing is when i free rev or drive it the speedo jumps randomly with the rpm, but only when the speedo is hooked up. i already cleaned the crap off of the solder joints on the back of the cluster and at the connector, didnt change much. any ideas?
boosted Comanche on megasquirt, 8.90"s in the 1/8th. getting faster one step at a time!!
vashxj
Vehicle Year: 1999
Re: tach signal, speedo problem
Post by vashxj »
Is there anyway to find the wires for the crank signal and trans output signal and just tap into them right at the pcm
turbojeeper
Vehicle Year: 1989
There is no pcm anymore. Its on megasquirt now.so alk I have is the coil negative/signal from the squirt and speed sensor signal straight from the sensor
turbojeeper
Vehicle Year: 1989
Well the speedo works again. Sensor wasn't tight in the tcase and had spun away from the gear.
