Jeep Stroker 4.7L
Posted: September 15th, 2013, 6:28 pm
Current Setup
-258 Crank and Rods - with Hesco Spacer
-Sealed Power Bearings and ARP Studs
-1990 Wrangler 4.0l engine
-Bored out .04 with new dished pistons
-High Flow Head, Ported and polished, oversized stainless valves
-Crane Cam
-2000 Intake manifold and electronics
-24lbs Reman Ford Injectors
-Header that works with the stock 2000 cats
-New O2 Sensors (upper and lower)
-Stock ECU
-Stock Coil Rail - (going to upgrade to SilverXJ's setup in a little bit)
-Fresh Build from Machine shop
I just finished the 1700 miles after I got it first installed. Initially it was working great but in the last 300 miles it started to have issues and threw misfire codes. For the break-in I had used Champion Plugs RC12ECC at a stock gap of .035. I think it started to throw codes after the rings seated. I just switched to the NGK ZFR6F-11 with a gap of .044 (I had to gap the plugs again when I got them, they came as .040) and reset the OBDII. I just ran the truck for a day and it just threw a code (haven't read it yet). Any ideas on what the issue could be?
Here are the images from the Champion plugs:
(Top plug is the cylinder by the firewall)
(Far right plug is the cylinder by the firewall)
-Crane Cam
-Stock ECU
