Banks Power's bolt-on Turbocharger Kit
CobraMarty
Post by CobraMarty »
Now in the new JP Magazine June 2013 issue
Gale Banks Engineering 4.0L Turbo system
for '99 1/2 to '06 Wranglers, requires the two pre-catalytic converters
50 state legal (pending)
Basic kit 6psi, average 45% increase in power, under $3000
includes everything needed for installation
Installs in less than 1 day, in your driveway
bolt-on exhaust mods, crossover and downpipe
cast bracket holds the turbo and shifts the alternator up a bit for clearance
Turbo has 46mm inlet diameter and 58mm wheel diameter
Turbo has integrated wastegate and blow-off valve
'T' and fittings tie into oil pressure sending port to supply turbo
Weld in 3/8" NPT bung for return line to oil pan
2.5" SS exhaust crossover and downpipe
includes 2-bar MAP sensor that plugs into factory harness
35 lb/hr injectors
Tuning-base kit includes analog boost gauge and Banks AutoMind
Tuning option- Banks iQ touch screen and Automind module +$360
requires 91 0ctane fuel to prevent detonation
optional side hood scoop to pull in cold air into engine compartment
optional intercooler and water-methanol injection allow up to 10psi
upgradable, install base kit and add options later
+66.1 rwHP and +83.7 rwTQ, peaks at lower rpm range
Stock- 137 rwHP at 4600 rpm, 177 rwTQ at 3750 rpm
Banks Turbo- 203 rwHP at 4450 rpm, 251 rwTQ at 3200 rpm
Over 225 rwTQ from 1950 to 4650 rpm
Finally. Nice kit for '99.5+. Where is the XJ kit?
99 XJ M62 S/C
