Hey guys,
Been awhile and I don’t mean to drop in a blast the forum, but I’m going to part with my toy and I was hoping I could reach out to you guys for a little input on price.
1988 2dr Cherokee sport. My first car when I turned 15. It’s been babied and will be missed. For the year, it’s extremely clean and has never been mudded or off-road since I have owned/built it. It’s got its few dings and dents, also has some pealing clear coat on the roof that I intend to Rhino Line. Fun little jeep to drive, awesome amount of torque, could smoke the tires if you wanted it to. Fun to hop on small V8 cars or rice rockets at the red light. Runs extremely strong and has less than 5k on the new engine and transfer case. Sad to see it go but have higher priorities right now. Lots of attention to detail put into the engine. Comes with a complete spare dash with OE radio, the project D44 axle which is complete but would need to be reassembled or built up to your specs. I also have a crap ton of parts that I have acquired over the past decade of owning/building this thing.
Engine build:
http://www.jeepstrokers.com/forum/viewt ... f=8&t=1180
Couple Exterior Shots:
http://i509.photobucket.com/albums/s331 ... C00815.jpg
http://i509.photobucket.com/albums/s331 ... C00827.jpg
http://i509.photobucket.com/albums/s331 ... C00834.jpg
http://i509.photobucket.com/albums/s331 ... age004.jpg
Engine:
4.6L
-4.0L Block 0.00: deck / 89 head and intake (CA smog)
-4.2L Crankshaft
-4.0L polished rods
-Hesco H-264-14B Camshaft and lifters
-Diamond pistons 24cc
-Total Seal rings
-ARP Connecting rod, mains and head bolts
-Clevite 77 Main,Cam,and Rod bearings
-JP Double roller Timing Set (0 Degrees)
-Stock Sealed Power stock rocker arms / hardware
-BB Chevy performance springs, caps and keepers
-Meling HV oil pump
-Bored throttle body 60mm
-Hesco HV water pump/thermostat housing
-AC Delete/alternator relocation
-Home brewed Port/polish on head and the first 5" of intake runners
-Accel cap/rotor
-Taylor 8.3mm wires
-Powermaster 150amp Alt
Drive train:
AW4
NP231 (Fully rebuilt less than 5k ago)
Tom Woods shaft w/Hd SYE
Dana 30/35c Yukon
Open 4.88s in the rear / 3.55s front (no front shaft installed)
Rear manche Dana 44 (Project axle comes with)
Suspension:
Mickey Thompson 15x8 Classics
Interco 33x12.5 Thornbirds (suck)
Rusty's 6.5" Coils
Rusty's 6.5" Leafs
Rusty's long arm
Rusty's Trac bar and modified drop bracket
JKS Discos
Poly motor and trans mounts
Drop pit arm
Rusty's nitro shocks
Steering conversion
Other:
3 core radiator conversion
Dual Permacool Electric fans
Dual Spal adjustable thermostats / relays
Cold air intake
Flowmaster 40 series dual out
Hesco ignition enhancement kit
Optima red top
Auto start alarm
Aftermarket electric door locks
Led interior lights
Tuffy center consol
Limited gauge cluster
Autometer mini warning light (oil pressure)
Autometer UltraLite gauges
- Wideband A/F
- Trans Temp
- Oil Temp
Scat seats
B&M Mega Shifter with custom consol
Grant GT wheel
Stereo
Alpine CDA-9884 Head
JL 4g Power / Ground / Fuses
RF Gama low levels
2 x RF P.2 10's 4 ohm DVC, Bridged to 2ohm, sealed box's .90qf
2 x RF 3.5" 2 way Highs
2 x Polk 6.50 coax
Need your input (Selling my toy)
- Jeep4xb4u
- Vehicle Make: XJ 2dr
- Vehicle Model: Sport
88' XJ 2dr
4.0l / AW4 / NP231 / D35c
- Jeep4xb4u
Re: Need your input (Selling my toy)
*Bump*
Any input on asking prices?
88' XJ 2dr
- superj
- Stroker Displacement: 4.5
- Vehicle Year: 1987
- Vehicle Model: wrangler
how much are other cherokees of that year going for? a lot of the mods you have done or added won;t increase the price, unfortunately. but with it being really clean, you can run it way on the high end of the price list and maybe a little bit more and hopefully a jeep person will come along and realize what you have done and get it. otherwise, it might be for sale for a fair amount of time if you list it too high.
We broke something, I think it was traction.
x2. I'd say ask $5k and let them talk you down a bit.superj wrote:how much are other cherokees of that year going for? a lot of the mods you have done or added won;t increase the price, unfortunately. but with it being really clean, you can run it way on the high end of the price list and maybe a little bit more and hopefully a jeep person will come along and realize what you have done and get it. otherwise, it might be for sale for a fair amount of time if you list it too high.
TXslayer
(if I had the money) I'd have no problem paying 4k for a cherokee that clean and well built.
Users browsing this forum: strokED and 1 guest
