I swapped the fuel injection from a 94 GC onto an 81 CJ5 but failed emissions. High hydrocarbons and high NOX. I suspect that I have the timing off and possibly the O2 sensor too close to the manifold as I installed it in the existing plug in the factory 4.2 manifold.
I know the timing is PCM controlled, can somebody tell me what full advance should be and at what RPM?
Also how far from the collector should the O2 sensor be?
Emissions fail EFI
Pedestrian
- Vehicle Year: 1982
- Vehicle Model: CJ5
Pedestrian
Re: Emissions fail EFI
Sorry about the duplicate thread. I'd delete it i I knew how.
Disregard the timing advance question I will reset the static timing per instructions found on this forum.
- cruiser54
- Vehicle Model: Comanche
With a timing light at idle, or when using my DRB, I usually see 12* of advance.
www.cruiser54.com
www.cruiser54.com
dupko
Yep,12*cruiser54 wrote:With a timing light at idle, or when using my DRB, I usually see 12* of advance.
