stainless headers wrapping??
atias
Post by atias »
what do you guys think?
is it gonna kill the stainless steel like it does to mild steel(cracks,rust,corrosion)?
just want to keep the underhood temp low , its getting crazy hot in here in the summer
:cheers:
CobraMarty
Re: stainless headers wrapping??
Post by CobraMarty »
Don't do it. Get them ceramic coated and use a thermal barrier sheet under the intake. Jegs has 'gold' sheets. Vent your hood- scoop, vents, cowl,lift, etc.
99 XJ M62 S/C
superstingray77
Vehicle Year: 1999
Vehicle Model: WJ
Post by superstingray77 »
Crap I wrapped mine a while back, so even if they dont get too wet it ruins them?
It most certainly lowered my IAT by a good 40-50 degrees over the unwrapped, this was just checked with the handheld live data scanner while cruising down the highway.
How long you think they will last? I am in Texas and it rains... oh wait... not anymore it doesnt.
Header wrap isn't good on any header.
atias
Post by atias »
mine are stainless so i though maybe they can survive this ????? :?: :?:
EVIL95XJ
Vehicle Year: 1995
Post by EVIL95XJ »
stainless can still corrode, especially wrapped
Ford 24# injectors - PM me
bandon
Learning to use the board
Vehicle Year: 91-4
Vehicle Make: JEEP
Vehicle Model: YJ
Post by bandon »
Ive wrapped my borla header twice over the last eight years and it is doing great. I also put a thermal blanket around my intake manifold. Also cowl induction hood, there was a significant drop in underhood temps.
I had three cheap remote thermometers from radio shack taking various readings but cant recall the actual drop in temp.
YJ,4.6 stroker/blower,Hesco Alum head,SOA SYE D44, 35" ,PSC ,Borla,AEM FMU, apexi neo, bap,2 walbros,2 Optimas, btm MSD, hydroboost, pw, PICS: http://photobucket.com/albums/b207/bandon_/
I personally wouldnt go that route.. just dont like the idea and i can only think of what will happen with Moisture/mud/whatever trapped under there. I would (and did) go with ceramic coating...
UncleWally
Vehicle Year: 1984
Vehicle Model: CJ7
Post by UncleWally »
I made a 2.5" mild steel crossover tube for a GM 6.5 Turbo Diesel, had it ceramic coated inside and out. Then used a header wrap over that, to also include the donut areas where it attached to the factory exhaust manifolds that I also had ceramic coated. I used the same ceramic coating on the exterior of the turbo housing (exhaust side) and a 3.5" mandrel bent down pipe, wrapping the downpipe and using a blanket on the turbo housing.
It worked awesome, a noticeable power increase, considerably lower under hood temps, egt's were lower due to larger mandrel bent 4" exhaust system, etc. When I pulled everything off to sell the truck, it was still in very good condition after 75k miles of hard use, including Minnesota winters (read tons of road salt and chemical).
I wouldn't be afraid to do it again......
Brian
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
