injector help
flexin91xj
Vehicle Year: 1991
injector help
Post by flexin91xj »
I'm going to the junkyard tomorrow looking for injectors to put in my '91 Cherokee.
What vehicles should I look for that have injectors I can use in my '91 XJ. I'm gonna try to get two sets. A set for my current 4.0 with a few mods.(19lb) And another set for the stroker I'm building.(24lb or higher)
What should I be on the look out for? Any special tools I need to remove the injectors?
Thanks...
A Hummer is just a Hummer, but a Jeep goes all the way.
Re: injector help
I wouldn't unless you want to send them off to get cleaned. Injectors that sit with fuel in them may end of stuck.
Re: injector help
SilverXJ wrote:I wouldn't unless you want to send them off to get cleaned. Injectors that sit with fuel in them may end of stuck.
Agree. Might be a better idea to search in ebay instead.
flexin91xj
Vehicle Year: 1991
Re: injector help
I guess Ill just order some off eBay then.
Whats the highest flow injector I SHOULD go on a stock 4.0 with intake, throttle-body, and mild exhaust? From what I've read, is to either go with the neon 703's or the mustang #19's. If I read the forums correctly, I wont get more fuel with those 2 injectors but the atomization is much better.
Any thoughts on a fuel pressure regulator on a mainly stock 4.0? Is that something I should put on once I get new injectors?
604rail_king
Vehicle Year: 1995
Re: injector help
Post by 604rail_king »
If you are on a mildly moded 4.0, stock injectors should be more than fine. Unless you have indicators that you need more fuel.
On ebay, there's a seller named precisioninjectors. He sells rebuilt upgraded jeep injectors for a very reasonable price.
flexin91xj
Vehicle Year: 1991
Re: injector help
Im bidding on a set of six neon 703's for $40 bucks at the moment. The aucten ends tomorrow so I hope I get them.
cruiser54
Re: injector help
Post by cruiser54 »
www.precisionautoinjectors.com. He also sells on ebay. I've used his injectors on three of my 4.0s and they work great. No guesswork.
www.cruiser54.com
flexin91xj
Vehicle Year: 1991
Re: injector help
Great website find cruiser54! THANKS
