Cam question
Posted: January 11th, 2012, 12:39 pm
by Wagoneerxj
Are there any aftermarket cams, good for a mild 4.6/4.7 that will allow me to run stock valve train parts? .
I ask because I'm on a budget (like everyone else!) and I can get the comp cams I see are popular on here, for roughly half the price of an OEM camshaft. Thanks!
Re: Cam question
Posted: January 11th, 2012, 12:48 pm
by Muad'Dib
Mopar Performance "Purple" camshafts.... got the 229AC in mine and its seems great. Stock Springs.
Re: Cam question
Posted: January 11th, 2012, 2:17 pm
by Wagoneerxj
Awesome thank you. How about any of the Comp or Crane cams? Just curious because I can't get Mopar parts where I work.
Re: Cam question
Posted: January 11th, 2012, 10:41 pm
by Retlaw01XJ
I'm new to Jeeps, but I've been reading the stock springs are lift-limited to around 0.450". (correct me if I'm wrong!)
I'm eying the Crower 44243. It's dual pattern with 194/204 duration, and 0.437"/0.445" lift.
The Crane 750501 has 192/204 duration and 0.427"/0.456" lift
Comp 68-201-4 has 212/212 duration and 0.447"/0.447" lift
The more popular Comp 68-231-4 and 68-232-4 cams both have lift over 0.460"/0.475' so there may be coil-bind issues.
Here's a nice summary of the different cams:
I'm searching for valve spring options as well that don't cost a fortune and will work with a higher lift cam.
Re: Cam question
Posted: January 12th, 2012, 10:04 am
by 604rail_king
with the max lift of .450 on the stock valvetrain, one could then get the comp sk68-201-4 which is a kit that includes new lifters and a dual timing chain ... makes the cam upgrade relatively low cost.
http://www.summitracing.com/parts/CCA-SK68-201-4/
