I have a little time on my hands so I am researching some info for an 88 Jeep.
Here is what I've come up with so far. Please feel free to add/ change anything.
I have also posted this on the Renix Yahoo group.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Coolant temperature
Hotter the coolant the lower the resistance
Adjusts A/F ratio
colder=richer hotter=leaner
Adjusts: injector pulse width
idle speed
advances timing when cold
energises EGR valve to shut off EGR when cold
[A- sensor ground to D3 on ECU, coolant temp in from B
to ECU on C10]
Deg F Resistance
-40 100.7K
0 25K
20 13.5K
40 7.5K
70 3.4K
100 1.6K
160 450
212 185
Manifold Air temperature
Adjusts A/F ratio
idle speed
[sensor ground on A to D3 on ECU,air temp input on B to D8
on ECU]
Deg F Resistance
-40 100.7K
0 25K
20 13.5K
40 7.5K
70 3.4K
100 1.6K
160 450
212 185
Manifold Absolute pressure
Measures barometric pressure vs. engine load
A_Ground
B_ 4-5 VDC cold, 1.5-2.1 VDC hot [.5-1.8VDC at idle
Manifold vacuum high 3.9-4.8vDC at deep throttle when manifold
vacuum is low]
C_ ?
Adjusts A/F [by injector pulse width, spark timing,idle speed,
EGR flow, shift light, O2 heater relay.
MAP sensor input to pin 6 on ECU]
Throttle position sensor
Measures position of throttle plate
A_5vDC
B_ground
C_ closed-.8vDC, open-?
[A- 5v supply from C15 on ECU
B-Ground to D3 on ECU
C-TPS input to C7 on ECU]
Idle air controller IAC (Idle speed stepper motor)
volts?
ohms?
Idle stepper motor
volts?
ohms?
[A on motor to B3, B on motor to B6, C on motor to B5
D on motor to B4]
O2 sensor
a-b 5-7 ohms (heater)
b-c ?
[O2 low(rich) <2.5V , O2 high(lean) >2.5v]
[ ECU connector under I/P to right of steering column A7
to pin 2 on Oxygen sensor heater relay connector
( relay ground) next to right hand shock tower to pin 3
on relay (B+ for O2 sensor) to A on O2 sensor.
B-ground on O2 sensor
C-O2 sensor out to D9 on ECU]
Knock sensor
retard timing under detonation/knock/ping
Volts?
ohms?
[A - on sensor to D8 on ECU, B-on sensor to D16 on ECU]
Crank position sensor
a-b 125-275 ohms
a-b .5-.8vDC when cranking ( wiring side?)
Engine speed sensor
[200 ohms +- 75 ohms]
from A-C1 from B on sensor to D1 on ECU
Sync pulse from distributer
[A- ground
B-sync in to ECU on C16
C-sync supply from ECU on c5@ 7.1 V]
Engine crank signal
Renix info wanted
jbxx
- Vehicle Year: 1986
- Vehicle Model: CJ7
- cruiser54
- Vehicle Model: Comanche
Re: Renix info wanted
Very interesting!!
One thing I caught was CPS output voltage. The numbers are correct but it's AC voltage.
www.cruiser54.com
www.cruiser54.com
