Cam swap??
YJason
Cam swap??
I'm running a comp-cam 68-231-4, while my engine is apart should I switch to a different cam?? The engine ran great and I was happy with it, but I have heard different ones say they've had bad luck with this cam. Whats your opinion?
Re: Cam swap??
Run it again(esp since you were happy w/ it). Wait for the comp chimers. . .
Re: Cam swap??
While I had one fail, I think you should run it again. I ran two CCs in the past and this is the first one that failed, although the true reason is unknown. Make sure you keep the lifters on the same lobe that they were originally on. If not, use new lifters and re run the break in.
Re: Cam swap??
????SilverXJ wrote:I think you should ruin it again.
x2 on the rest of SilverXJ's post.
Re: Cam swap??
fixed
YJason
Re: Cam swap??
I think I will run it again, thanks for your opinion
