I noticed that some of you were slightly confused on how to use images within your post, so i figured i would make this post. This little write up is just making it as easy as possible, although there are many ways to do the same thing. I do also want to be clear that this is the preferred method to add images to your posts... attachments are more for files that your trying to share than images.
Upload your image to a free image hosting place like TinyPic:
http://tinypic.com/
When you upload it, it gives you links to choose for posting. One of them will be called:
Code: Select all
IMG Code for Forums & Message Boards
It will have a link that has
 before and after it. Once you have this link provided to you, just copy the link to the clipboard (its more of a "virtual" clipboard) by highlighting the link and holding the "ctrl" key and pressing "C". Once you do so, you can paste the link into your post by holding the "ctrl" key again, and pressing "V" Just for for the sake of saying it, you now know how to "Copy and Paste". Your pasted link will look something like the link below:
Code: Select all
[IMG]http://i28.tinypic.com/rtqanr.jpg[/IMG]
This is the ideal way to post your images on this board...
Hope that helps.
