Mercury Marauder Injectors
- StroktWJ
- Vehicle Model: Grand Cher
Does anyone know what lbs injectors are in the 03-04 Marauder? I don't have the part number handy right now, and I have googled it. I come up with no good info
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
Re: Mercury Marauder Injectors
2C5Z 9F593 AA
- StroktWJ
anybody have an idea what pound they are? I was figuring they would be #24's since its a 4.6L DOHC, but would like to be sure
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
- Muad'Dib
I used google found the information in less than a minute.
Ford 2C5Z-9F593-AA ... same as:
2C5E-9F593-A4A
2C5E-A4A
Motorcraft CM5035
Standard FJ774
2C5E-9F593-A4A
2C5E-A4A
Motorcraft CM5035
Standard FJ774
Code: Select all
cc/min @ 3 BAR
272
lbs/hr @ 3 BAR
25.9
Ohms
12.2 If it feels right, then STROKE it!
coas
Probably 24lb/hr but what about spray angle and orientation, number of beam, spray type, spray distribution???
Injector flow is only one of many characteristics you should consider when upgrading. A mismatch can cost dearly.
4 hole. Angle? umm... I've never seen an injector that sprays sideways. distribution?
coas
Spray distribution (area, spray amount):
12°-24°¤>40%
8°-20°¤>30%
4°-20°¤>35%
0°-8°¤>50%
These are some examples, design by the intake ports shape they intended to and air velocity. Too wide and you will wash the ports, too narrow will yield insufficient atomization..
Spray angle alfa-80 is the cone characteristic, can be 12°, 15°, 20° or else.
The Neon injectors are perfect fit. the spray distribution is a match (8°-24°¤>42%) to the 4.0L ports. Spray angle is 25°, orientation is 0 and one beam.
12°-24°¤>40%
8°-20°¤>30%
4°-20°¤>35%
0°-8°¤>50%
- StroktWJ
Muad'Dib wrote:I used google found the information in less than a minute.
2C5E-9F593-A4A
2C5E-A4A
Motorcraft CM5035
Standard FJ774
Code: Select all
cc/min @ 3 BAR 272 lbs/hr @ 3 BAR 25.9 Ohms 12.2
Damn I have been "googling" this for weeks!!!
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
Where do you fins such specs, and which neon injectors are you referencing?coas wrote:Spray distribution (area, spray amount):
12°-24°¤>40%
8°-20°¤>30%
4°-20°¤>35%
0°-8°¤>50%
coas
The data is from Bosch books/manuals and the Neon injectors are 0280155703.
yuppiexj
I think we have a Bosch injector guru now.
- Muad'Dib
Those suckers are cheap too...coas wrote:The data is from Bosch books/manuals and the Neon injectors are 0280155703.
coas
Cheap as a used set but way expensive as new than those injectors you can buy from the known injectors shops.Muad'Dib wrote: Those suckers are cheap too...
0280155710 the Ford yellow 210cc retail price is $60, Rockauto.com.
0280155703 Neon injector retail price is $112, Rockauto.com.
price for one injector.
Those Neon injectors also don't have the EV6 connector, so one would also have to factor in the prices for the EV1 pigtail or EV6 to EV1 adapter if your current injectors are the old style.
Coas, what info do you have on the Bosch 0280155865 injector?
coas
The later Neon injectors, 97-99, 0280155784, are with USCAR plug. Same spec as 0280155703.
But, I don't see why later models with EV6 or EV12 injectors need switching injectors unless need more flow. For these there are the 99 Taurus injectors 0280155849.
0280155784
Note, those injectors are for stock 4.0L or slightly modified. Not for strokers. For a stroker use 0280155715 out of 96-98 Taurus/Sable.
0280155865 is a ~255cc/min injectors/24lb/hr with 2 beam at 20°.
Spray orientation angle 90°
Spray distribution 8°-20°¤>40%
length 74mm
USCAR plug
Used in 01-04 Mustang Cobra and Mach 1
0280155784
length 74mm
USCAR plug
